Backhoe backhoe movements
   / backhoe movements #11
From looking at the gearbox drawings, Tat2z1969 appears to be correct. It looks like the pto shaft is driven by the upper shaft (which drives JM rear hyd pump). The pto speed selection apears to be done via sliding gears on the pto shaft. ie only the pto shaft would change speeds. I can not confirm engine speed rotation, but seems consistant with the small gear on the upper shaft driving the larger gear on the pto shaft. The drawings I reviewed were the older 3 bolt hole cover vs newer 4 bolt. Thanks Tat2z for dis-spelling my assumption.
2003 Ferris IS1000 52in Zero Turn Mower (A51691)
2003 Ferris IS1000...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
Case CX160C Hydraulic Excavator (A51691)
Case CX160C...
2015 Kia Sedona Van (A51694)
2015 Kia Sedona...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
