backhoe with post hole digger attachment
   / backhoe with post hole digger attachment #1
harry forson
can we get to purchase a backhoe that has post hole digger attachment? or an auger drill that can be attached to a backhoe to drill holes in the ground for fencing works and other works?
   / backhoe with post hole digger attachment #2
Welcome to TBN. :)
   / backhoe with post hole digger attachment #3
Yes, most of the hydraulic PHDs that can be attached to a front bucket can be attached to a back hoe bucket.
Since you mentioned fencing work I assume you are considering relatively small/light equipment, e.g. Cat 2 or Cat 1 tractors.
The major benefits of hydraulic post hole diggers are that they are reversible and typically protected by hydraulic relief valves.
a) If they get stuck you can back them out.
b) If they jam or run into some solid obstruction there is at least a chance that the relief valve will open before or instead of a sheer pin breaking.
Against these benefits is their initial cost, which could be justified if you intend to drill many holes in conditions where jamming is likely.
   / backhoe with post hole digger attachment #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Attachments Forum. You'll get a better response there. ;)
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53473)
2020 Westfield MKX...
