Bad day for my BH90
   / Bad day for my BH90 #11
I'm been in the market for the BH90 for a small contracting/landscaping business I am starting. I also noticed the other post about a bent cylinder. (Don't remember the model of the hoe) This does make one pause! The L48 would fit my needs perfectly, however I would prefer to made do with what I have. Has this worked well for you up to now and how many hours do you think you have on it? I also have read many posts of people who are happy with the BH90 so I'm taking that into consideration as well. Hope you can get it repaired under warranty!
   / Bad day for my BH90 #12
Agree with the plan:
Try warranty first, then take the cylinder to a shop. They should be able to salvage the tube and build a new piston........
A sad set of pics indeed.
ron
   / Bad day for my BH90 #13
</font><font color="blue" class="small">( There was somebody else recently who posted about some problems with a Kubota backhoe having a bent cylinder.)</font>
I thought the same thing when I read this most recent post. I looked back, and I this was the other post:
BH75 Piston broke, twice! Design problem??
So two different models now, a BH75 and a BH90, but both are new. Hope these are isolated occurrences and Kubota takes care of both people involved.
<font><font color="blueclass=small">( I'm been in the market for the BH90 for a small contracting/landscaping business I am starting. I also noticed the other post about a bent cylinder. (Don't remember the model of the hoe) This does make one pause! The L48 would fit my needs perfectly, however I would prefer to made do with what I have. Has this worked well for you up to now and how many hours do you think you have on it? I also have read many posts of people who are happy with the BH90 so I'm taking that into consideration as well. Hope you can get it repaired under warranty! )</font></font>
Until yesterday I was quite happy with the BH90. While it did not have all the power in the world, it did a fine job for its size, and when I tackled something too big for it, it just stalled, telling me I needed to figure out a different way to do the task. (a good reason for not messing with the hydraulic pressure)
I have dug many stumps over the past year and never had a problem. Heck, this one was even coming out of the hole and I bent the shaft after I released and was trying to get a better grip.
Chris
   / Bad day for my BH90 #15
I believe that when all the smoke has cleared, we will learn that Kubota changed suppliers of hydraulic cylinders and that there is a defect in the new product. It is also possible that some penny pinching bean counter has specified a less quality item to save a few cents and it is now backfiring. If they balk at replacing it under warranty, then I would start making rumblings that the machine isn't fit for the purpose intended and that by design, it is of inferior quality. Then I would be talking to an attorney about bringing an action against the dealer. If these bent cylinders continue, possibly there will be enough people to start a class action lawsuit...
   / Bad day for my BH90 #16
Ahhhh "penny pinching beancounter", the root cause of so many problems. The ones with MBAs are the worst. Has anyone ever heard of one paying the price for his mistakes? The ones I know of all got promoted. /forums/images/graemlins/crazy.gif
Sorry to pollute a perfectly good thread.
Bob
   / Bad day for my BH90 #17
Bob........ I would respond to your MBA comment, but I don't want to shut down any more threads this month. I have already caused 2 closures, and one to disappear. The way things are going, I am starting to believe the rumor about a bounty on my head... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Bad day for my BH90 #18
I have been checking out these latest Kubota backhoe cylinders bending. I am sure Kubota will fix it as they really seem to fix problems quickly.
I have noticed that all the bent cylinder rods were at full extension as that is when they are under the most strain. This could be a binding problem with the pins as well as metallurgy or design problem.
I will guess and toss out a design problem as Kubota is right on top of their game here. Could be the steel, but my guess is binding at the joints. Might be lubrication or the pins may be galling due to metallurgy.
If the pins bind all the power has to go somewhere and that would be bending the rod. All cylinders have their weak points and that would be at full extension. Ideally the hydraulics should set to stall before anything bends or breaks.
I try to use my backhoe carefully on borderline stress jobs and pry with the cylinders in. Having said that I won't waste time trying to baby it too much as it should hold up and has so far.
I am not a engineer yet (slowly work on a degree), but I am a Tool & Die Maker, Machinist and Welder. Not saying I am right but I do have experience. Let us know what happens with Kubota.
ksmmoto
To comment on binding, I doubt it. Friday night was the first time I chaned out the bucket, to try out the 12" bucket, and when I switched, and switched back to the 18", I greased the joints, so it happens that it was JUST greased before this happened.
I will say though, when I pulled the pin out it seemed like it could have had more lube in it. I mean, it has grooves to hold the grease, but I just expected more area fo rthe grease to spread out, I guess.
Chris
   / Bad day for my BH90 #20
His was on an L39 if I remember correctly. It was volfvandt I believe. Not sure if the BH was a 90 or another style. But it was during the curl time his bent also.
UNUSED LANDHONOR ABC-13-125A HYD BRUSH CUTTER (A54757)
UNUSED LANDHONOR...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
2001 John Deere M665 (A50120)
2001 John Deere...
