Oil & Fuel bad fuel tanks bx2200
   / bad fuel tanks bx2200 #1
Anonymous Poster
Epic Contributor
I have been having a main fuel tank leaking problem on my less than 50 hour bx2200 ! The dealer has replaced it once , and now is going to pick it up again to check it out . It looks as if it is coming from a seam , but its hard to tell . I just wondered if any one has had this same problem lately, as i know there was some problems with the tanks earlier on.The bx2200 is a great machine , but it seems like mine has been giving me heart failure with alot of stuff going wrong . I will say the dealer ( after a few phone calls) has been great with trying to remedy the problems . Just wanted to see if mine is the only one having this tank failure .
jim
   / bad fuel tanks bx2200 #2
This has been covered before, but to recap, early BXs had a problem with the small resevoir tank (not the main fuel tank). Then it seems that there was a batch or two that had a problem with the main tank where the fuel sender is attached. It seems that the sender wasn't fitted properly to some of these tanks and diesel would come out at that point and run down the seam, which made it look like it was the seam leaking when indeed it was just how the sender was attached. Kubota has issued a service bulletin and a kit to fix this issue. The new kit clamps in the fuel sender via an internal collar, while from the factory the sender was a slip fit, which worked fine as long as the tank opening was proper. I guess the problem came when some tanks didn't have the perfectly round opening, allowing the sender to come loose.
   / bad fuel tanks bx2200 #3
There is a thread talking about this issue. In general there is a Fuel Stay Kit #K2561-96140. Do a search on Fuel stay and the thread will show in the list.
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
