Bad head gasket ?
/ Bad head gasket ? #1
Jimmy6657
Case275
I have a 1974 international 2400a 3 cyl diesel. Runs good doesn’t seem to smoke more than usual but oil is grey and overfull. Are these known for head gasket or is it something more serious ?
/ Bad head gasket ? #2
Are you losing water? Some models if fuel pump leaks can put diesel fuel into the oil.
Take a sample of the oil and put in a clear jar or glass and let sit. Then you can see what separates out. Another test if water is drip some in a warm
Pan does it sizzle and steam? Be careful if you try that though since the steam bubbles might burst spraying hot oil.
/ Bad head gasket ?
Thanks for the info I will try those tests
AGT Industrial SSECAG-Y QA Auger w/ Bits (A60463)
AGT Industrial...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
John Deere 6300 (A60462)
John Deere 6300...
2003 POLAR TANK (A60736)
2003 POLAR TANK...
ALLMAND MAXI-LITE II V-TWR (A60736)
ALLMAND MAXI-LITE...
SD Lanch SDLD25 (A60463)
SD Lanch SDLD25...
