Bad hydo pump on my 2310! HELP!
   / Bad hydo pump on my 2310! HELP! #11
If the pump fails,,,,you still can drive it??:confused:
Yes. I am not sure why, but according to previous accounts, that seems to be what happens when the shaft strips out.
   / Bad hydo pump on my 2310! HELP! #12
When I look at the AGCO parts manual I noticed the hydrostatic pump is the part that sticks out just above the mid pto shaft-where the engine drive shaft goes in and the hydro pump is inside so it looks like two different systems?
Mine had only enough drive to get it on the trailer. After that, nothing.
dans12345 said:
Today, for the second time I went to use my Massey 2310 and it moves back and forth but no hydraulics anywhere. The first time was covered by warranty. They said the splines on the shaft were too short. Thought that the problem was solved, but I guess not.
Any help would be appreciated.
I'll post my parts numbers for the "upgraded, hardened/lengthened" parts. Is it possible they replaced your old crappy parts with the same old crappy non-upgraded parts? I know chevy used to replace bad parts, with the same bad parts.
Wacky said:
Have you met with the regional rep?
You could always write a letter to MF and ask to speak with the CEO. You may get someone to help. Just some ideas. I hope the best for you.
Thanks for the info. I still haven't done anything about it. I'm planning on calling the place where I actually bought it. They move a lot more product than my local dealer.
Here are the parts # for the pump and gear
Pump 4265224m91
Gear 4264915mz
Case Backhoe (A55973)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
1992 Ingersoll Rand (A55973)
1992 Ingersoll...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
