Bad sheetrock prep for paint
   / Bad sheetrock prep for paint #21
I would probably use a 8" (Drywall) knife to scrape the loose materials of & avoid digging into the existing drywall. Go back and clean it with some TSP and dry it. Let it set a day or so and inspect for any added spots that pulled up when cleaning. Use a good scrubber pad with warm water/TSP mix. From there use some sandpaper (not screen) for the latex paint edges on a pole sander to knock down the edges some. Dust it down with a clean damp rag & dry it out with a heater for a while and air movement. Skim Coat bad spots, with a thicker mix of Durobond 45 (dry mix that you mix up like concrete in small batches) it will fill/seal any low spots. (Might need overall skim coat/2nd coat of DUrobond but it is hard to sand so don't pile it up.) Let it dry down and hit it with course screen on a pole and top coat it with lightweight topping skim coat. (Note it may take 2 coats of topping, use a light close to wall to see/find low spots.) Lightly sand top coating and use a GOOD KILZ primer for wet area let dry and top coat paint with preferred paint. I don't care for the combined (paint/prime) in the mildew resistant paints but have not bought any of the NEW stuff as I'm set in old ways...
Mark
TMA (A49461)
TMA (A49461)
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
2013 FREIGHTLINER CASCADIA DUMP TRUCK (A54313)
2013 FREIGHTLINER...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Mobile toilet with shower (A53424)
Mobile toilet with...
