robstaples
I need some engineering support. My application is putting a camera on the top of a pole to watch a bald eagles nest. I have various options for poles and cameras. The camera I want to use is 17 lbs and the one I have up now is 9 lbs. This will be in addition to the one I have up now.
So I am specifically wanting someone to tell (or point to) the formula for frequency of oscillation of a weight on the end of a pole: base fixed and weight up in the air. It is like a inverted pendulum with a stiff string. But the forces are all different. Heavier weight and less stiff pole, and longer pole will make the movement greater.
What are known are:
the weight of the camera on the end
moment of inertia of the pole( will vary with material and dimension)
and length of pole.
I've included some pictures because we all love pictures. This nest is in my front yard and this camera is 80 yds away in my back yard, on top of a 40 ft black pipe pole. I want to extend my tri leg tv tower with a single pole with camera on end.
Eagle summary: Parents here for 2nd year, nest 106 up in white pine, had 2 eaglets, raised both, first to fledge broke his wing after 5 days of flying. Local eagle rescue has him and may return after healing in 3 more weeks. Remainder is being taught to scavenge and fish. Parent dropped 12 sucker on my walk way within sight of the nest. Eaglet didn't fall for it, ( or come down for it) so parent came down and ate it, 12 hours later. Great entertainment!
I will be using my Kubota to man-handle my tower during modification.:
Thanks in advance,
rob
What are known are:
and length of pole.
Thanks in advance,
rob
