Ball valve vs. Needle Valve
   / Ball valve vs. Needle Valve
Do NOT put any of these valves on the IN, OUT or PB ports on the valve. They only belong between the valve and the cylinder you want to slow down, not in the "main flow".
Use 1/4" hose to feed your grapple, it's cheaper and easier to route-3/8" is a waste of money.
Slow the RPM's on the engine a little to slow things down if you feel they are moving to fast for you.
I misspoke (actually miss-wrote) when I said "all of the FEL controls", but it would have been before the diverter for the grapple and bucket curl/dump function. But, got it, not between the FEL control and diverter. Was going to go 3/8" all the way to a bulk head at the front of the loader in case I used it for something other than the grapple in the future. Not a good idea?
   / Ball valve vs. Needle Valve #12
Good, just wanted to make sure you understood;)
As for the 3/8" line...What is the GPM output of your pump? What other than a grapple could you power? Possibly a hydraulic post hole digger depending on your pump flow...a snowplow does not need 3/8" hoses.
Not much need for a snow plow down here in Houston! :laughing:
And not many GPM on my CUTs implement pump: 6.2. Haven't looked at the requirements on a post hole digger, but that was I was thinking. May not be thinking far enough ahead though.
43055 (A55851)
43055 (A55851)
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
John Deere 7410 (A53317)
John Deere 7410...
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
