Ballast Box
   / Ballast Box
Some people...
The bushing kits should be a lot cheaper than that! Was is BW15056 that he quoted?
TSC also sells them, as well as: QUICK HITCH ADAPTER KIT CAT 1-3
I have no idea what he ordered, I did it over the phone. Below is from JD's "build your own" web site.
iMatch / Quik-Coupler Bushing Kit BW15056 $71.00
   / Ballast Box #12
I just purchased a 2010 3520 w/FEL and considered a ballast box but I went with a 450 lb. 72 in rear scape blade. JD was offering a 700 dollars off on two implements so the FEL counted as one and I went with the blade. I thought I might as well get something I can use instead of a box with no use besides weight. Yes you have to watch what you're doing when you back up or swing around but you should be doing that anyway.
JD 3520 w/ FEL and 72 in. rear blade
Kubota ZD28 60 in.
Gravely 14 hp Kawasaki 50 in. walk behind
Stihl pruners, string trimmers, blower
18' Landscape trailer
14' Heavy Duty Trailer
JD 4010 w/ 10.5' Bush Hog
JD F-620 54 in.
2000 Chevy Silverado 1500 Z-71 4x4
2001 Chevy Silverado 2500 HD 4x4
Landpride FSP 1000 3 pt. broadcast spreader
   / Ballast Box #13
Problem is, 450 lbs isn't much weight for ballast...read your loader manual.
   / Ballast Box #14
My little 2520 has 1,000 lbs in ballast box, and it will still pick the back end up a little if I try to lift huge load with loader.
450 lbs is better than nothing, but you will find that you need alot more than that.
   / Ballast Box #15
Hmmm,this is interesting,mine won't do that. If I try to lift too much,my loader,(for lack of a better word) relieves itself. It just won't lift until I reposition.
Aren't the relief valves on all 2520s supposed to be set at the same pressures?
Greg
   / Ballast Box #16
Kubota ZD28 60 in.
JD F-620 54 in.
In all due respect a ballast box can do more for your TRACTOR than a rear blade ever will.
Go get a bucket load of wet dirt and take a peak at your front tires. I did. Scared the crap out of me as I thought both tires were going to explode right there and now.!! Not to mention the front axle.
A 3520, I would guess, should have 1000lbs. of ballast. Your manual will say.
   / Ballast Box #17
My 2520's R4 tires don't squat hardly at all when properly inflated. :cool:
   / Ballast Box #18
Greg
I'm "Guesstimating" 1,000Lbs in my box.
Its most noticable if I try to pick up something with the corner of the bucket, that picks up one of the rear tires with ease.
   / Ballast Box #19
The idea of using an implement is okay, but it needs to be heavy enough to do the job. I don't have a ballast box either but I use a 1250 lb boxblade when I need something compact behind my tlb.
2008 Cadillac Escalade ESV 4x4 SUV (A51694)
2008 Cadillac...
2016 JOHN DEERE 8245R LOT IDENTIFIER 188 (A53084)
2016 JOHN DEERE...
2012 Ford Explorer (A50123)
2012 Ford Explorer...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2018 FREIGHTLINER...
