Sysop
Elite Member
- Joined
- Jun 7, 2013
- Messages
- 3,301
- Location
- Fairmont, WV
- Tractor
- Mahindra 4035HST purchased 2013 - Husqvarna TS348-D purchased 2019 - Craftsman 42" HST purchased 2003
So fish gills are actually Fuel Cells???
There is oxygen dissolved in water... along with other things. Pure, deoxygenated water, no, but try to get SOME
4Fe(s) + 3O2(aq) + 6H2O(l) --> 4Fe(OH)3(s) ..... rust formed under water
4Fe(s) + 3O2(g) + 2H2O(l) --> 4FeO(OH)(s) .... the most common form of rust
2FeO(OH) ---> Fe2O3 + H2O .... the reaction for the dehydrate of rust
Yes, I guess I wasn't holding dissolved to the same definition as you. You're right, oxygen and the other gasses required by life can be suspended in and then diluted to various levels within water, as can many minerals and solids, but none of the chemical makeups are combined or changed. Sometimes you can have reactions between these suspended and diluted substances which will cause some oxidation and such to occur under water, but again, once any of that suspended oxygen is used up, the oxidation process stops (nearly if not totally). I'm no chemist, but I believe those tables showing the makeup of the various oxidation processes simply shows the variances in the process as other elements are introduced to the process. I've still never heard of H2 simply losing it's O stored in a closed container.
