Barn foundation tall wall - vertical rebar??
   / Barn foundation tall wall - vertical rebar?? #31
I have it in my garage floor and after a short time, all the fibers that stick up are broken off and you can't tell the differance.
The point of the contraction joints is to force any non-structural cracking, that usually occurs due to shrinkage as the water dries, into the pre-cut joint. You see these all the time on sidewalks for example. It's impossible to prevent shrinkage cracks and so convention say it's better to plan for them and get them to go hide in the pre-planned joint than to appear at random. These joints usually made by putting a small T-like piece on the face of the form. Or in a slab by inserting such a piece into the surface of the concrete.
   / Barn foundation tall wall - vertical rebar?? #33
Bebster - I sent a private e-mail to you several days ago. Did you see it? /forums/images/graemlins/confused.gif
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52748)
Hay Van FL-95 Bale...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
