Barn loft uses... not hay
   / Barn loft uses... not hay #12
Just don't goof like I did making steps over a foot tall! :) 20180503_172739.jpg20180503_172653.jpg
   / Barn loft uses... not hay #13
Pallet forks on the FEL?
Thinking more on the electric winch raising about a 4'x4' platform up thru a trapdoor in the ceiling. Thought the old pulley and rope on the outside would work too.
   / Barn loft uses... not hay #14
Where I grew up my Granddad built a small barn like this in 1942. I wish I was there to take a picture, I'm terrible at sketches. The main section is 2 story cinder block I'm guessing about 30'x20' deep. Either side is like a wood pole shed. Bottom double doors and upper have windows, each bay window in back , windows in front and back of middle section, so plenty of light.
Roof overhangs about 6ft. so even with doors open no rain/snow.
Top roof where loft doors are that section you walk out, almost level. There's a 8x8 post out about 8ft with pulley and rope.
   / Barn loft uses... not hay #15
When we moved down here from Alaska there was an old two story barn - from the original homesteader. Sold that old barn to a contractor who used the wood in some fancy-dan rec room in an uber expensive house in Spokane. Wish, now, that I had that old barn. I live so far out in the stick here - the upper floor would have been a good place for my still.
   / Barn loft uses... not hay #16
I have an old 36' x 36' barn with a full hay loft. I place all sorts of spare parts, lumber, tin and misc things up there that I seldomly need. About once a month I will climb that ladder and retrieve some "treasure" for a project or repair. I even have a car engine, a 275 gallon tote and a "spare" riding lawnmower up there (the loft door is 44" wide and I use my tractor loader and front forks to lift big items up there).
   / Barn loft uses... not hay #17
The possibilities are endless...
Build it and worry about how to use it later. Cheaper to build it now rather than later.
   / Barn loft uses... not hay #18
My Dr. turned his unused haymow into a party barn. He has a bar, several tables, pool table, air hockey, pinball machines, etc. He even has a porta-potty just outside the door a few feet.
   / Barn loft uses... not hay #19
Now, there's a thought! Father-in-Law had his woodshop in his. All his equipment could be bolted down instead of being moved and in the way when they were in his garage.
   / Barn loft uses... not hay #20
Lofts are cute, but expensive and useless. Build a building you can drive into, for hay, equipment, parts, or shop use.
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
2016 Chevrolet Sonic LS Hatchback (A55758)
2016 Chevrolet...
1999 FORD F550 BOX TRUCK (A54313)
1999 FORD F550 BOX...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
