Barn Project - post holes filled with water
   / Barn Project - post holes filled with water #11
What kind of floor are you going to have in this barn? Gravel, Concrete? Dirt? I have to agree that the best method to deal with a water table so high, is to pour a good footing and attach your poles above ground.
Some years back, when my Dad had his dock built, they drilled and installed 16" tubes, installed the rebar cage, poured the concrete into the tubes. they didn't pump out the water. The concrete was damp enough to displace the water. They used vibrators to get any trapped air out. Foreman told me it would set up just as hard as any other concrete. He said that such a little water mixed in, that they could even do it in salt water? You might check with some dock workers to see if they use a special mix. I guessing they use a 6 bag mix.
Are you going to have to worry about your equipment flooding during the rainy season? /forums/images/graemlins/frown.gif
Good luck
   / Barn Project - post holes filled with water #12
Building my house during the rainiest summer we ever had, all my porch footing holes were full of water the day they wanted to pour.
The concrete guys pulled the mucky few inches of clay at the bottom out of the holes with post-hole diggers. Then they just poured the concrete in without pumping out the water. The excess water floated out the top and did not significantly mix with the concrete.
- Rick
2022 BARFORD TR8036 MOBILE SCREEN (A51242)
2022 BARFORD...
197711 (A51244)
197711 (A51244)
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2017 CASE SR160 WHEELED SKID STEER (A51242)
2017 CASE SR160...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
