Barn raising, sortof
   / Barn raising, sortof
I'm open to any suggestions or to a website for ideas or calculators. I have talked to structural engineers but they admittedly are not super familiar with in place wood truss construction and tend to want a steel solution, with columns down the sides of the 10 center section. I would really like to find a wood truss engineer but have been unable to locate one without buying pre-manufactured trusses, which would require completely redoing my barn roof.
Any input would be appreciated (except getting rid of the bird or the spouse, I'm quite attached to both of them.)
   / Barn raising, sortof #12
Would idea 1 be possible using two longitudinal beams with columns at each end? This would only be for the length of the motor home.:confused: :confused:
Structural firm and specify wood. I'm sure a design can be done.:D
Will the modifications have to be certified and inspected?:D
The structural people that did the modified scissors design looked at a longitudinal beam design but at the peak. In steel it was way more expensive than the modified truss and in laminated it was no better. I may have to go with some form of columns if the modified scissors will just not work.
Not sure yet on the inspected. It's not a domicile and in a rural area and the building is already there with no changes in the sq ft to affect taxes. It is my preference that they would not have to be involved but we're not as easy here as where Eddie Walker is.
   / Barn raising, sortof #14
You have several problems, and each of your truss designs create as many problems as they solve. The sissor truss was my first thought, but it would be expensive, and at 30 ft, beyond my abilities to design. It's just too far of a spread to know what it will take to build it.
Your other designs fail to address the spread of the walls. Tying them together is as important as keeping your pitch.
I think you have three options. The cheapest and easiest is to put in load bearing posts. The ones you have for your horse stalls would be a good location for that side of the building. Replace what you have with some 6x6's that are either in the ground deep enough for your area, or on footings that are strong enough. You'll have to determine that for your area. Put a double header on top of the posts to support your rafters and then tie the tops of the posts on either side of your RV together with a joist. Kind of like your drawing, but with posts to support it.
Your second option is to spend allot of money and put a load bearing beam across the peak of the roof. Either the length of the RV, or the full building. This will be very heavy and pricey, but it will allow you to keep your freespan. If it was me, I wouldn't do this, as it's a very big job. To support the beam, you will have to have another across your door as a header, and have the right amount of support for the load of that beam concentrated at both ends of it. Not my idea of a quick,easy solution.
My best, and probably cheapest in the end, solution is to extend your barn with a roof design for your RV, or just build another barn for it. You can do it Pole Barn style with posts in the ground wide enough to get your RV in there and put trusses over it. 16ft wide won't be that dificult to truss and I'd be you'd be money ahead building from scratch then trying to engineer something that will work in what you already have. Sometimes it's ALLOT easier,faster and safer to start from scratch.
Run the numbers, including labor, and I think you'll be suprised.
Good luck,
Eddie
   / Barn raising, sortof #15
I'm going to go out in left field and throw out another idea ....a bit out of the box.... May not even be doable - but it's a thought. Go in the barn the length of your motorhome and find a spot where your trusses now sit directly on a stud. Take a circler and sawzall saws and cut the barn in half. Now release the bottom plate from the foundation, nail some blocking to the walls, borrow some hydraulic jacks, and jack the entire end of the barn up. Now build some walls to place under the old bottom plate and fill in every where else. ....I said it was from left field ...
   / Barn raising, sortof #16
How long is the barn?
How long is the motor home?
What is the spacing of the ties?
You only need to modify an area long enough for the motor home right?
I have a crazy idea. I just need answers to these questions.
   / Barn raising, sortof #17
Ill run a couple of trusses in the softwere tomarrow when im at work.....
Your only hope is to sister some trusses next to the existing rafters.
YOu could go with some 32" OC ones that you can set next to every other rafter.
YOu can also go with a stronger structrual ridge beam with some LVL that ties into a girder truss 30' in. (so you only have to have one truss) Then you would be able to move the celing ties up and add as second collar tie.
Ill run some calcs tomarrow see what i come up with.
   / Barn raising, sortof #18
you can get 30' 4/2 sissors 32" OC (every other rafter) 2x6 over 2x8 with 25-5-1 loading
hears a hint from the truss profesional..... if you spec out a truss that has like a 2x6 heal height that gives you addtional room to manuver the truss in to place. then you just shim the bearing up tight once its inplace and plumb.
alternativly you can get a fairly simple 2ply girt flat BC truss 30' in to carry the 6750lb point load (30psf total load) at the peak from a new ridge beam. But the ridge beam is going to be something serious.... (multiply large LVL)
but that would allow you to more easly move the existing celing joists up and add collar ties to each rafter at ~ the 1/3 span point.....
The original barn is 30X70 feet. A 25' garage addition was added on the west end.
Motorhome is a 26' 1974 GMC. I would like to get it into the building by 3 or 4 feet to have some work/walk around room at the back.
Actual length is about 28'. Ties are 48" apart, rafters are on 16" centers.
The "barn" is built on footings with a block wall. It's real construction, not a pole type building.
schmism said:
Ill run a couple of trusses in the software tomorrow when I'm at work.....
You could go with some 32" OC ones that you can set next to every other rafter.
You can also go with a stronger structural ridge beam with some LVL that ties into a girder truss 30' in. (so you only have to have one truss) Then you would be able to move the ceiling ties up and add as second collar tie.
Ill run some calcs tomorrow see what i come up with.
The scissors truss design in one picture is from the lumber yard building design staff. They are proposing these on 32" centers. They also considered a steel beam along the ridge but passed on that due to cost and weight. No mention was made about using LVL as part of a solution. Their proposing that this truss would be built on site by adding the lower member to the existing rafters.
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
UNUSED FUTURE 48" LAND LEVELER (A54757)
UNUSED FUTURE 48"...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2005 Kaufman Trailers Car Hauler Trailer (A55788)
2005 Kaufman...
2016 Caterpillar 349FL Hydraulic Excavator (A55787)
2016 Caterpillar...
