Barrel and rotary hand pump set up for Diesel - best parts to use
   / Barrel and rotary hand pump set up for Diesel - best parts to use #11
Did it work for you when it worked? All I need is to fill up a 7 gal tank on my tractor. Trying to keep it simple and find a good pump.
Yes. It did work pretty good. The one I used was locked up when I got it. I took it apart and cleaned it up and got working. This one really needed rebuilt.
I used it many times after priming and filled 20 gal tanks pretty quick it seemed.
The lever pumps work even faster, but that rotary pump will work fine too
   / Barrel and rotary hand pump set up for Diesel - best parts to use #13
I think you did good for $222. As far as the hand pumps , I've found the lever type to work better and faster than the rotary type
I ordered the rest of the parts today. A bung adapter to go from the 64mm course threads on one of the barrel openings to 2" NPT for the fill fitting. I picked up a cast iron Vent fill fitting at Tractor Supply - was on their clearance table for $10. It has a locking cap that also works as a vent. No sense locking it as it can just be screwed off.:laughing:
Last I ordered a yellow heavy duty plastic pallet off of Amazon. I did find them locally, but Amazon was cheaper and the local vender did not want to budge on price. I was used too.
So in about a week all the parts will be here and I can assemble it. I just need to pressure wash the barrel out.
2017 Dodge Charger Sedan (A51568)
2017 Dodge Charger...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A51244)
UNUSED FUTURE MINI...
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
1049 (A50459)
1049 (A50459)
