Basement?? Panelized, Poured, ICF, ???
   / Basement?? Panelized, Poured, ICF, ??? #11
My house is built with Arxx ICFs for the foundation and Enercept SIPs for the above ground walls. Very happy with both. The nice thing about the ICFs is the ability to easly make the basement walls as high as you wish. My BIL wanted 9' basement walls and had a hard time finding someone with forms that size. I'm sure Superior Walls come in any hight you want also.
Your floor plan looks as though it has quite a few angles and jogs. This would certainly be easy to do with an ICF system. You also end up with walls that are insulated inside and out.
Running wire in an ICF wall is easy. Just run a router with a 3/4" straight bit where you want the wire. Some builders use an electric chainsaw to make wire channels.
A neighbor down the road used the Superior wall system and there is no footing. Only compacted gravel. I'm not comfortable with that myself, but I guess it's OK.
Very happy with the SIPs too. Went together well and no problems.
I'm in the planning and research phase right now. I haven't broken ground yet. I'm probably going to do that in the spring as I still have to finish the remodel on my current house and sell it first.
I do appreciate all the info on these wall systems.
   / Basement?? Panelized, Poured, ICF, ??? #13
Gary,
I can not tell you how happy I am to read about how happy you are with the combination of systems I've been considering. /forums/images/graemlins/grin.gif
The idea of building a deeper basement and taller above ground walls is very appealing to me. I want a 9' finished ceiling in the basement which will probably entail going with a 10' basement wall. I know I'm going to get hosed buying 7' doors instead of the standard 6'-8" doors but it's worth it to me not to have to duck in my own house. /forums/images/graemlins/wink.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/cool.gif
   / Basement?? Panelized, Poured, ICF, ??? #14
Our ceilings in the finished basement are 8' 7". Could have been 9' but we used a truss type floor joist system rather than the engineered I beams. I believe the trusses are slightly deeper than the I beams. But using the trusses allows all the water, electric, and HVAC lines to run in the floor joists without any drilling or cutting required. All of our lower level is finished except for the utility room. So the ceilings are flat with no need for boxing in utility chases. Can't tell the difference between up stairs or downstairs.
A pointer for SIPs that my contractor ignored: Be sure to rip the sill plates for the SIPs to the required size. Mine were supposed to be 2x6. The panels have a 5 1/2" opening in the bottom for the 2x6. But using PT lumber, the 5 1/2" dimension is sometimes oversize. The panels were hard to slide into position. If he had ripped the lumber to correct size this would have made the assembly easier.
If you want to see pictures of our project, look here: http://www.w0gom.net/
   / Basement?? Panelized, Poured, ICF, ??? #15
Gary,
Thanks for the link and for the tip. /forums/images/graemlins/smile.gif
   / Basement?? Panelized, Poured, ICF, ??? #16
I'm looking into putting a walkout/driveout basement underneath a 30x40 polebarn effectively doubling the storage capacity. Superior Walls here in NJ contacted me immediately and gave me a rough quote of $80/LF for their 10' walls so I figure about $12k plus the cost of a flooring system such as Spancrete.
   / Basement?? Panelized, Poured, ICF, ??? #17
I went with Superior 7 years ago -happy as can be still today. They were rather close by with their plant and at the time were very helpful and highly competitive with pricing. I dislike block, poured is very expensive here, and after 6 months of trying, I couldn't locate any ICF distributor/contractor,etc. so it was good that I was interested in Superior. Part of the crew showed up at 6 am to compact the stone, panels showed up at 8:30, by noon they were wishing me well and pulling out of the driveway.
You need to look at the local situation - price and support infrastructure that is nearby for each option. That will give you the most bang for the buck.
Good Luck,
   / Basement?? Panelized, Poured, ICF, ??? #18
Personaly, fancy concrete wall systems don't start to show thier real value until you get above the ground. I don't like the "wall panel" concept. I want a monolithic pour, no joints ever 10 to 20 feet. Panel systems have high Shipping costs. On their web site, no footers=> No thanks! I saw on another post where they mention poured concrete wall cracking. If the proper footing and R-bar is used, it will take heavy equipment to crack the wall. There is no comparible strength wall system to a concrete wall. Go look at a parking garage.
I too am getting ready to build on a hill. I have looked at many concrete systems. Do you want the best thermal system? Easy on the ele and plumbing install? Use local labor and contractors? They are very key to your choice. I was set on the T-Mass concept, Concrete/Foam/Concrete. From a thermal point of view, better than ICF, SIPs and wood frame comstruction. Finding a contractor was hopeless. Even though it a simple system, inserting foam between standard forms, I could not find any contrator willing to take the time/chance. All utilities also had to be run in advance. ICFs were starting to look better. DIY or any contractor with a level can build with them. The wife and I attended the "World of Concrete" exposition out in Vegas two weeks ago. In the end Fox blocks looks like the best buy. This company is the largest ICF manufacture, making many brands for other lables. Just recently, they started marketing their own brand. Prices are listed on their web site unlike most others, less than $3.00 a sq-ft. First load is free delivery, second load is $1 per block.
We are going to build with nearly 100% concrete. Two stories on a bacement and concrete floors and roof. The floor systems I had first chosen was the Insul-Deck/Lite deck concept. Basicly a foam form that creats beams and deck all in one pour. The issue I saw was again, the diffaculty in running ele/plumbing/heating-cooling. I have settled on Hambro floor system. Steel truss that forms a composite concrete/steel floor joist. Their sales guys state $9 per sq-ft labor and material. This will be good for the radient heat. Also, Hambro has spans up the 33' !
Keep researching and good luck.
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
