SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,391
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
When you have implements that deal will driveline impact pulses the added cushioning of 140 can be a comfort issue. Mostly not necessary, but some benefit at least a little above the noise. You factor this against higher viscous drag losses and its no brain why trucks use the lighter oil, esp since there is no driveline impact in their systems.When I got a recent Woods mower, the manual stated using 80w90 or synthetic 75w90. Same was true for the Landpride reverse tiller I got last year.
That being said, most, if not all, commercial truck fleets use a synthetic 75w90 in the differentials of the trucks. I am apt to believe that yanking 80,000 lb up and down mountain passes all day long in high ambient temperatures (with no oil cooler) is a little more brutal than what most of us here would put on a piece of equipment on a 3 point hitch. I have an '06 International semi that has had nothing but 75w90 in the rears, per Eaton, and it has almost 550,000 miles on it with no problems. And it regularly pulls almost 80,000 lb up and down hills year round. I guess that is why I am not so concerned with putting a good 75w90 in a gear box on my tiller or mower.
larry
