Bath Room Electrical?
/ Bath Room Electrical?
If the ceiling is 8 feet, how about some nice track lighting, aim a flood beam into the unit from outside. That would give you enough light to put on a show in there :) and have room for other heads to accent or light up other areas.
But even if you just used it to light the shower it might be the easiest way to go? though track lighting in a bathroom may raise other code issues, not even sure it would be allowed?
JB.
Mike stated that track lighting in a bath room is not allowed.
http://www.tractorbynet.com/forums/projects/199483-bath-room-electrical-5.html#post2304122
/ Bath Room Electrical? #73
theres nothing wrong with filling up the whole box......thats what the knock-outs are for.
the biggest problem is the connected load. this is not something that i can exactly list right here, especially since i have actually taken an 8 hour long course on load calculations, and still sometimes get confused.
you cannot simply add up the total number values on your breakers and say i have 1000 amps of breakers on a 200 amp panel. it doesn't work that way.
they have factors like averaging 3 watts per sf of floor space for lighting, if you have 3 dryers, they take 100% of the load on the first and only 30% of the load on the second and third.....stuff like that
NO ONE runs everything at the same time. i can wire each bedroom on its own 15 amp breaker, but i may actually only be drawing 3 amps load on that circuit.
so like i said...its really hard to calculate. its on a job by job basis. My house is hooked up to 400 amps, with 200 going to feed the shop,barn and lighted arena.
the other 200 amps feeds my house. I have a mix of gas and elect appliances, but find it interesting that i can run nearly my entire house on a 50 amp generator. so 200 is overkill.. I dont have a well, so that helps.
i've tripped a 200 amp breaker in the past from a dead short, but generally its the smaller breakers that trip. if you keep tripping a 15 amp breaker, don't JUST PUT IN A 20 AMP BREAKER UNLESS YOU KNOW FOR SURE THAT THE WIRE RUN IN THE WALLS CAN SUPPORT A 20 AMP LOAD. Otherwise you can invite us over for the marshmallow roast on the resulting fire.
best to split the load on the existing circuit and add a new feed.
/ Bath Room Electrical? #74
I don't find load calcs to be terribly hard, just a bit tedious. But most importantly they seem quite low for residences. 3w/sf for general lighting, add in the greater of the AC or heating load, then the required bathroom, laundry and kitchen circuits, and an electric range (I forget the derating factor). I think that was all of them, but I'm not gonna bother looking it up right now. If it says you need over 150A, you have a huge house.
Here's a good REAL load example for you: my garage. I have a subpanel temporarily setup in there as I am using it as my woodshop annex. I used a 150A subpanel but connected to a 60A breaker in my main panel which is plenty (plan is to move the 150A panel to the new shop when we build). The most I've had running on it was my 3hp Dust collector (20A 220v breaker), my wide belt sander (on a 30A/220V), my 30A 220v electric heater, and several fluorescent lights. All from that panel. Heck even the 5hp compressor has come on in there too as the sander needs air to tension the belt (30A 220v). All pulling through a 60A breaker ... Never tripped a breaker. Add that all up and you'd think I should trip like crazy. Well I never start 2 motors at the same time (intentionally) and that is the biggest issue with tripping. Most motors do not draw full load in use, so there is more headroom than you might think, and all the big stuff has it's own breaker too.
Let me head off the safety police: the subpanel is rated for 150A but only connected to a much smaller 60A breaker in the main panel, using properly sized wire, and is perfectly fine. The reverse would be the hazardous setup: 60A panel fed from a 150A breaker.
/ Bath Room Electrical? #75
This has gone a bit past what I need, but I guess it's ok.
Can anyone shed some light on what type light to use in a domed tub shower unit?
Here's one idea. You can install a recess light with a shower trim in the domed ceiling. It's always a little hairy cutting a hole in one of those fiberglass tops, but I can tell you how I've done it.
1. After choosing a recess light, use a rotozip tool with the optional circle cutter attachment to cut your hole. The rotozip makes a hole in the center. Then the pin on the circle cutter goes in that hole, and the rotozip tool circles around it until you've gone the whole way around. Voila! Note: If the top is already installed before you've cut your hole, you'll want to definitely wear safety glasses and cover your head because fiberglass dust will be coming down at you from above. I thought I'd find lots of uses for my rotozip, but that really hasn't been the case. But this is one job where it really shines.
2. Then, just install the recess light in the hole. What kind of recess light? I use the "remodel" style. Because the fiberglass is so thin, and remodel lights usually attach to 1/2" - 3/4" thick ceilings, you might need to use some 1/2" scraps of wood for the clips on the remodel light to press against on the backside of the top, close to the hole you just cut.
I've done this installation with Halo H5RICAT remodel housing, and the Halo 5450PS shower trim. It looks nice when you're all done.
You can probably use just about any other remodel housing and shower trim combination. Just make sure that the trim is a shower trim. That way it'll be approved for installation in a wet location.
36"x12' Stacks of Sheet Metal (A60463)
36"x12' Stacks of...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
1996 Geo Tracker (A60352)
1996 Geo Tracker...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
pressure washer, and trailer (A56859)
pressure washer...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
