I don't observe regeneration is the miracle many make it out to be.
Oooh, you mean it might produce a HP using less fuel at low RPM than at high RPM?
"Efficiency" of High torque low RPM "Low load"
For heating the cabin.
Peltier crystals are terribly inefficient.
Yep hoping they eventually make a huge leap with peltier s
And interestingly, the thermal efficiency of an ICE is measured to the tip of the exhaust pipe. Cool the gasses and one affects the flow and salvaging from the combustion chamber.
I believe you meant Savaging
Not with the inefficiency of converting mechanical energy to electrical and then electrical back to mechanical. One happily eats this inefficiency with a diesel-electric locomotive or the huge earth moving trucks used in many mining operations due to the cost and complexity of a transmission drive. Electric hybrid drive preferred over hydrostatic or cut gears.
It will be interesting to see just how well this Stellantis design actually performs.
