Battery Box Needed, underground, watertight
   / Battery Box Needed, underground, watertight
Size?
About 3' x 3' square by 18" deep. Bigger is OK
Rich
   / Battery Box Needed, underground, watertight #12
Just do a goggle search for NEMA boxes and pick a supplier. Most will have something in the size you are looking for. Lowes carries a 12x12x6 plastic but that probably isn't big enough.
You could vent it with flexible water tight conduit into a fitting through the side. This could be ran below the surface to a fence post. Come out of the ground next to the fence post and put a weather head on it.
   / Battery Box Needed, underground, watertight #13
</font><font color="blue" class="small">( ...If it looks like this will not work then the batteries will have to be placed in the house and ...along with a very expensive wire to get the power at 48V/100Amps (and 250ft) from the PV panels to the inverter/batteries in the basement....)</font>
Won't you have this wire cost anyway? You'll need to get the power from the batteries to house somehow, and I doubt your going to be using 12/2 romex for that!!
The inverter will be out with the batteries so the wire coming into the house will be carrying 240volts so a much smaller wire. I think 6 guage will do but have not done the calculation yet.
Rich
   / Battery Box Needed, underground, watertight #15
Rich, would you mind sharing the make/models of the components you're using? I'm considering installing something like that myself. Thanks!
   / Battery Box Needed, underground, watertight #16
</font><font color="blue" class="small">( The batteries need to be placed in a watertight box in the ground. )</font>
Hey Rich, could you tell me why the batteries need to be underground?
Those nice Concorde batteres could go anywhere. <trying to envision how they would fit under my bed>
If it were me, and I were forced to bury them, the first thing I would look at would be a light wood frame, sheeted with 1/4" marine ply and wrapped in fiberglass cloth/polyester resin. In other words, boat construction. Sealing would require a stainless or brass wing nut every few inches around the perimeter of the lid.
I have a very small but very effective solar outfit that powers everything in my tractor shed, which is off grid. Although I'm delighted with it, I will never venture into anything bigger.
   / Battery Box Needed, underground, watertight #17
</font><font color="blue" class="small">( ...I have a very small but very effective solar outfit that powers everything in my tractor shed, which is off grid. Although I'm delighted with it, I will never venture into anything bigger. )</font>
How come? Cost, inconvenience, problems?
   / Battery Box Needed, underground, watertight #18
Why does the box need to be watertight? If possible, I'd rather use an open bottomed box on a bed of drainage gravel, maybe even with a drain tile.
If the box is watertight, then you need to provide a way to get the water out. I assure you, water will get in. Murphy and all that.
Strongwell makes a line of precast utility vaults and handholes that are the standard of the industry.
http://www.strongwell.com/PolymerConcrete/QuaziteProducts.HTM
Or you could build a concrete masonry vault and put a cast iron cover on it.
http://www.nfco.com/
Try to locate the box where it will not be subject to wheel loads, and if necessary, protect it with bollards or boulders to keep errant garbage trucks and brother-in-law's Caddies off it. If the box must withstand wheel loads, pick a vault and/or cover that's designed for H-20 loadings.
   / Battery Box Needed, underground, watertight #20
Rich:
With what you are doing I would maybe think small under ground ROOM, rather than just a batterybox. you will need AIRSPACE to keep cool the ground alone will not helpmuch what you need is SURFACE AREA for cooling. I would think a 6x6x10 room out of block with a poured top coat and a small staircase leading into it would be great. and double as a nucular bomb shelter! /forums/images/graemlins/smile.gif or if the wifie finds any letters form back when a room to stay safe in! /forums/images/graemlins/wink.gif
You can buy Control Panels (Nema 4X) but they are pretty expensive to get size big enough. You COULD get them here cheaper than most anywhere else, ( http://www.automationdirect.com ) look at Nema 4X though for wash down, and maybe a double door, that was lay it FLAT and build a small shed over the top... this does not give you the surface area but you can run a small DC or AC fan through a filter to keep them clean cool and dry...
contact a few local builders and or concrete suppliers for local help.
/forums/images/graemlins/cool.gif
Mark m
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
