battery for 2520
   / battery for 2520 #31
The smallest dual bank MK charger is a 10 amp chargerthat I know of, this should be sufficient to charge up your tractor battery. The only deep cycle batteries that run a lower voltage are gel batteries. Most wet cell and AGM batteries will all charge at a slightly higher voltage. I use a three bank charger to charge a cranking battery and two deep cycle AGMs' on my boat.
Good to take it in and have it all checked out though.
   / battery for 2520 #32
sldva00,
The first thing wrong is that you're guessing! Several things could be causing you problem, I'd like to know how many good batteries are returned every year because of poor trouble shooting.
What you need is a cheap digital meter. Measure the voltage of the battery with the engine and key off. What do you get? It should be in the area from 12 to about 13.4 volts. Lead/acid batteries run 2.2 volts per cell and there are 6 cells (13.4 volts). AGM (glass mat) run about the same.
The battery will most likely measure around 12.5 to 13 volts. Now start the tractor and run the engine about 1600 rpms (enough to charge a battery). Measure the voltage across the battery with the engine running. What do you get? You should see the charge around 13.8 volts maybe slightly higher. now you know the alternator is working properly.
If the battery reads, say, 10. 5 volts after a charge with the engine off it has a bad cell but before you rush to get a new battery make sure you don't have a short in the system.
Disconnect the battery and with the key off measure the resistance between the pos and negative terminals. It should be over 10k ohms (10,000 ohms), it may register as open but it should be high. If you read 500 ohms or less you likely have a short problem and it's killing your battery. Make sure when you check this you don't have any light switches or signals on.
With your tractor running relatively low rpms your battery should still charge. The difference between alternators (AC) and generators (DC) is that alternators need to spin much faster to generate charging energy. This is why they are geared way up so that when an engine is running above a low idle the battery charges. In short you're probably charging your battery even though you're running at 1400 or 1600 rpms with a good system.
Rob
ps: the original alternator on the 2520 is more than capable of charging the battery.
   / battery for 2520 #35
sldva00,
Yes I am guessing. I always check the voltage between batteries and alternators as you described. Unfortunately the Beckman gave out before my battery problems after 20yrs of use. Don't want to spend money on a new one, so will be visiting eBay soon. Looking for another Beckman Industrial.
This I did not know. Will do as soon as I replace my meter.
Thanks Rob
   / battery for 2520 #36
sldva00,
You might consider a Fluke combination vom/ac-dc current clamp. I like Beckman too but the Fluke is a better value, I have several of the Fluke meters now and used to have a Beckman 360. For sure all of these are overkill for these tests.:D
   / battery for 2520 #37
sldva00,
Steve,
I use Fluke meters too. Very good. My two old hand held model '77's are 25 years old. On the bench I use an Agilent 34410A, it's the cat's meow! Pricey though.
Here's the kicker, I just bought a relatively cheap Tenma (what's that? A kid telling his mother how high he can count?) clamp meter for my solar and it's great. True RMS and accurate, actually more than I need in a clamp meter but it was only about 85 bucks!
Rob
   / battery for 2520 #38
Dave
Thats a good price!
I use a Fluke 336 true rms clampmeter 600v/600a for my main clamp and have the cheaper Fluke T5-600's 600v/100a for each service truck. I have had good success and longevity from all of them. I try to keep a top quality set of test equipment at the office for more exacting requirements and more expendable gear on the trucks full time. Enough about that though.
I agree with you that in effect there is a need for a good diagnosis of the problem rather than guessing. I am sure we have all been in similar circumstances though as I feel naked trying to diagnose without test gear.:D
MURRAY 20" SIDE DISCHARGE GAS PUSH MOWER (A51248)
MURRAY 20" SIDE...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51248)
UNUSED FUTURE MINI...
PRECOR EXERCISE BIKE (A51248)
PRECOR EXERCISE...
