Battery For 35 Deluxe
   / Battery For 35 Deluxe #1
Ragged Edges
Fultonville, NY
John Deere 4500, Massey Ferguson 35 Deluxe (Work in Progress Project)
Im hoping to get the 35 (gas engine)that I aquired moved back to my house this weekend. I does not not have a battery and was wondering if anyone can tell me what size or a make / part number of a battery that will work in this? I called our local tractor supply and they said thay only had a 6 volt battery listed and I kno that isnt correct. W have another farm supply store local that I hope to contact today. I wasnt sure if I could just go to a auto parts store and have them reference one for me. any help is always appreciated!
Mike
   / Battery For 35 Deluxe #2
G'day we use delkor 22f520 in those it is too small for the holder but is more than enough battery to start these
Jon
   / Battery For 35 Deluxe #4
is a TO35 or MF 35??
TO could be 6 volt
MF most likely a 12 volt
Look at your coil it might have the voltage on it somewhere
if it is a 6 volt go ahead and convert to 12
   / Battery For 35 Deluxe #5
WHat makes you think 6v isnt correct?? A lot of old tractors are still 6v. And as mentioned, if this is a TO35 delux, and still has the generator, it is 6v. If it has an alternator, then someone comverted it to 12v.
If it is indeed 12v, just go to TSC or your choice of parts stores and get any 12v battery that will fit in the battery tray. (Take some measurments before you go)More CCA the better, but also more $$$. At least a 600-650CCA should be fine.
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58216)
2018 ALLMAND...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2018 KENWORTH T880 HYDROVAC (INOPERABLE) (A58214)
2018 KENWORTH T880...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
