Battery hot wire (witch one is the hot?)
   / Battery hot wire (witch one is the hot?) #1
BC4
Cartersville, GA.
Mahindra
Hi All,
I have a 2816 Mahindra and I took the battery out. To put it back I am not sure
witch terminal is the hot side (or ground side). One has a yellow stripe down it
and I think that is it. It does not have any markings.
Anyone know for sure and how can I tell?
Bob
   / Battery hot wire (witch one is the hot?) #2
Follow the cables, the positive/+/hot will go to the starter solenoid, the negative/-/ground will go to the frame or engine block somewhere.
   / Battery hot wire (witch one is the hot?) #3
not by color. can you follow the leads to see where they go. the ground side should lead to a bolt that is on the frame of the tractor. most use red color cable for hot (+) side.
   / Battery hot wire (witch one is the hot?) #4
my 3016 is the one with the big plastic connector attached to it along with the starter cable. It's the one on the 'driver's side of the tractor.
Should be the same as yours.
   / Battery hot wire (witch one is the hot?) #5
Are you saying that the cables are both Black? The positive should be red insulation all the way or at least have a red insulating cover on it to cover the battery terminal. The - or ground side wont have a cover on the cable and should be black. Failing those two requirement for electrical wiring, just do as suggested and find where the cable goes to ground and put it on the minus side (-) of the battery post.
   / Battery hot wire (witch one is the hot?) #6
Agree, follow the cables. I am betting the one with a yellow tracer is the ground.
   / Battery hot wire (witch one is the hot?) #7
Normally, battery cables will 'take a set' as to how they want to lay; replacing the same battery they should want to fall to the respective posts. Most batteries have the posts offset to one edge, so if the cables don't reach it needs turned around. As a last resort, the posts are different sizes and the negative clamp would have to be widened considerably to go onto the positive post, so that should be a red flag.
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
Rotadairon RD145 Pull-Behind Rotary Tiller Tractor Attachment (A59228)
Rotadairon RD145...
SAMSUNG REFRIGERATOR/FREEZER (A60432)
SAMSUNG...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
