Battery Terminal Corrosion Prevention
   / Battery Terminal Corrosion Prevention #11
Clean connections, then a liberal coating of Vaseline. It's worked for me for 30+ years. Kubota recommends greasing battery connections.
   / Battery Terminal Corrosion Prevention #12
You can neutralize and get rid of the acid with a mixture of baking soda and water. Once the acid is gone, clean the terminals and the cable's connectors up real nice. If the cable's bolts have built up corrosion than you can put never-seize on them to help prevent future build up. Get some of those red and green felt like washers that prevent corrosion and put them over the terminals. Put the cables back on the terminals and snug the bolts down. Take some of the dielectric grease and paint it all over the outside of the terminals.
If doing all that doesn't solve your problems than I would look into a new battery.
:cool:
   / Battery Terminal Corrosion Prevention #13
clean then coat liberally with axle grease.. I've yet to find anything better...
soundguy
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A57453)
2005 International...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
PALLET OF MISC PARTS (A58374)
PALLET OF MISC...
Rolling Steel Hoist w/Chainfall, 9' W x 12'H (A59076)
Rolling Steel...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
