Battery treatment chemicals for sulfation?
   / Battery treatment chemicals for sulfation? #1
SPIKER
Elite Member
Ohio, Jeromesville, Ashland County
Jinma 284
hi All;
I done & left the key on the tractor a full week a couple of weeks back /forums/images/graemlins/blush.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif and even after re-charging the battery it appears that there has been some damage to it. it (the battery) charges up to 12.0 volts & holds that LEVEL of voltage using the charger and even starts the tractor fine in this warm temps.. I know it SHOULD read 12.8~13.4 or so un-loaded. I remember some type of battery additive that was something like "X-14" or something which claimed to knock off the "plate sulfation buildup" which is what causes low voltage usually. I will be out there and check the battery today with a HYDROMETER so I'll know a bit more on it's condition tonight. I was hoping to see if anyone has used any of that x-14 stuff and if so where did you get it and what was the results? /forums/images/graemlins/crazy.gif
ok anyhow got to get going to the farm.
MarkM
ok thanks for the help
MarkM
   / Battery treatment chemicals for sulfation? #2
Yep. VX6 is one brand. VX 6
I've used it. It works great unless the battery has a cracked or broken plate. Never seen but one with a broken plate.
I've used it in tractor batteries and used it in one that had a crack in the outside. Sealed the crack up with silicone and put the VX6 in and started the tractor right up.
The first battery I tried it in I did the mfg. test that they had on the label. This battery would charge just a little. You dive around a while and sometimes when you turn the key it would just click. I'd roll it off and get it started and next time it might start with the battery. Just before adding the VX6 I turned the head lights on and left them on till there was no light from the lamps. Turned the lights off, poured the VX6 in, and got in the truck and turned the key to start. It fired right up. I ran that battery until I traded the truck which was 4-5 years.
We also used the VX6 in the big 48 volt batteries for AC electric fork lifts. These batteries weighed over 4,000 pounds. It was a lot cheaper to use the VX6 than change out those cells when they went down. These were in a textile mill. Ran them 24hrs a day. One battery on charge, one cooling and one in the lift. So yes it works.
   / Battery treatment chemicals for sulfation? #3
Mark you can get a battery pretty cheap these days if you aren't needing an Optima. Before I would dump 25 bucks worth of chemical in a battery that may or may not work afterward I might be checking the price for a WalMart battery. /forums/images/graemlins/confused.gif
   / Battery treatment chemicals for sulfation? #4
</font><font color="blue" class="small">( Before I would dump 25 bucks worth of chemical in a battery that may or may not work afterward I might be checking the price for a WalMart battery. /forums/images/graemlins/confused.gif )</font>
Mark, maybe Junkman can get you his employee discount at WalMart to save a few more bucks. /forums/images/graemlins/grin.gif
Ken /forums/images/graemlins/smile.gif
   / Battery treatment chemicals for sulfation? #5
</font><font color="blue" class="small">( Before I would dump 25 bucks worth of chemical in a battery that may or may not work afterward I might be checking the price for a WalMart battery. /forums/images/graemlins/confused.gif)</font>
You only use 4 ounces of the quart per normal sized battery. It is also available in auto parts stores in the 4oz. bottles. Works well in most cases, but after a while, there is no saving any battery. I use it in the Wally World batteries after about 3 years and get another 2 or 3 years of service out of them.
</font><font color="blue" class="small">( Mark, maybe Junkman can get you his employee discount at WalMart to save a few more bucks. /forums/images/graemlins/grin.gif
Ken /forums/images/graemlins/smile.gif )</font>
"Wake up, if you want your dreams to come true." The only thing you get as an employee at Walmart is grief from the management and the customers. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Battery treatment chemicals for sulfation? #6
You could spend $40 and get a 'Battery Minder', which is a small charger with a computer chip that can de-sulphate a battery as it charges it, and will not overcharge, so it can be left hooked up and charging for months at a time. The nice thing about it is that you can use it to charge and de-sulphate every battery you own - vehicles, tractor, RV, marine, etc.
HERE is a link to a website that sells the Battery Minder.
   / Battery treatment chemicals for sulfation? #7
You mean to say that no one has their battery acid tested every 100 hours or so ? I mean really! How can you judge a battery without knowing the sulfate content ? Just shooting in the dark I guess.....
Ben /forums/images/graemlins/smile.gif
   / Battery treatment chemicals for sulfation? #8
Here is a trickle charger that sends a pulse through the charge that desulphates the battery electrically. I almost got one this weekend for one of my vehicles but then I saw a crack in the side of the battery so I went with the wal-mart replacement for $30.
http://www.batterymart.com/batteryminder.php
If anyone has used one of these please let me know how it worked out.
   / Battery treatment chemicals for sulfation? #9
Hey Junk could you spare 4 ounces out of your quart for Mark and pay shipping too? /forums/images/graemlins/wink.gif
Hi All:
here is the readings from the hydrometer:
each cell was almost dead on 175 (which was on this unit dead center on the re-chagre area of red tape coloring.) which is good and wondering why news. now the battery is a PITA one which sets down between the rad & under the air filter. I pulled the air filter housing loose already to make access to the battery easier and all the water/acid levels are pretty much dead on where I set them some 3 years back now. /forums/images/graemlins/smile.gif /forums/images/graemlins/laugh.gif I can't belive that myself I figured simple evaporation would have claimed a bit of level ? that VX6 may be what I was thinking about.
as for those big ole honking forkilft batteries yep I had to work on those a lot too. I'm a maintenance mech but only filled the water levels if needed on them as the 1st shift was the battery tech. he used open torch flame to solder on the terminals on those batteries /forums/images/graemlins/crazy.gif /forums/images/graemlins/ooo.gif while he showed me how to braze/weld / solder them on I said naw & let him do that while i handled the mechinacal stuff /forums/images/graemlins/wink.gif I value my face un-acid etched...
anyhow I put it back on 3 amp trickle charger for 12 hrs, (forgot to check that today too ;( /forums/images/graemlins/blush.gif ) and this time connected the leads dirrectly to the battery posts.
anyhow back to the battery at hand it is a big one, heavy and hard to get out, I installed it and found it was easier to install the colwing AFTER the battery was in on the 2nd one I assembled. (note this is a china battery and weighs about 80 lbs full. /forums/images/graemlins/ooo.gif not something I want to mess with with the messed up back... anyhow it is still partly dissassembled and I'll try and find soem of the VX6 or what ever it was mentioned above. I remember this stuff and heard great things about it and was told by the CLARK REP for the forklift batteries that they used it in everyone they set out as a pretreatment... /forums/images/graemlins/wink.gif note this was a local dealer so maybe different in/at other locations. that was 4 yrs back or so now so I couldn't remeber the name of it right...
anyhow I stopped at autozone and talked to the guy who didn't / doesn't know his rear from an exhaust and well you get the picture... he wanted to sell me a new battery and said they don't even carry acid anymore unless you want to pay for it na dhave it shipped in for each use type thing. this guy is one I've had to deal with befor and I already knew his answer befor asking (pretty much the same thing every time a blank stare like some one asking for a moon rock or proof of life on other planets! /forums/images/graemlins/crazy.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/tongue.gif
any how this computer was acting up and seems to be having some mental problems of it's own so I'll get back here if it keeps going this week. I have too many things going on at once.
1. battery problem,
2. adding spring seat to the tractor /forums/images/graemlins/smile.gif 70 buck job from TSC seems nice for a inexpensive seat. /forums/images/graemlins/smile.gif
3. arrived home to soaking bathroom floor from a leak /forums/images/graemlins/mad.gif
4. computer didn't start up and had to change & re-load bios 2 times /forums/images/graemlins/mad.gif even /forums/images/graemlins/mad.gif er
5 sandblasted the chrome off the BBQ grill top as it started flaking this weekend rinit a load of burgers & dogs /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif Not sure if I'll still use this grill top but I think I'll fab up a small round one like my big one I made, 1/8" thick .5'x1" expanded metal one snd doubbled it up so there is a cris cross thing going on so burgers don't fall through so easy or stick so bad.
6. put in window ac units. one down 2 left.
7. dig my own grave as if I ever get all this done I'm sure it will kill me first lol /forums/images/graemlins/laugh.gif
8. keep smileing as every one already knows I'm nuts so might as well proove it /forums/images/graemlins/wink.gif
MarkM
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2000 ADDCO DH1000 Message Board (A49461)
2000 ADDCO DH1000...
2020 KUBOTA RTV...
3in Poly Pipe (A49461)
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
1997 TRAILMOBILE 48X96 FLATBED TRAILER (A50854)
1997 TRAILMOBILE...
