Batwing Blade Sharpening
   / Batwing Blade Sharpening #1
clee4020
Mississippi
Kubota M9540 HD 4x4
How do you sharpen blades? Do you take them off or sharpen while still on the bushhog? I've tried both, just curious how others do it. Also, how do you get to the center blades? The way I do it is probably not the safest, but I put blocks of wood behind the batwings wheels and then pick up the tongue with the FEL, then prop timbers under in case chain breaks. Just seeing if others had a better way.
   / Batwing Blade Sharpening #2
I haven't had to do mine yet but the wings look easy, of course, and it looks like I might have enough access to the center section blades from alongside it.
Ken
Forklift Safety Basket Attachment (A55787)
Forklift Safety...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A55788)
2002 Ford F-250...
