BB How much weight to add
   / BB How much weight to add #1
Hookblock
WI
JD 4310
I have a 6' king kutter BB on the back of a JD 4310 and was wondering how much weight to add to it. Or what others have added to there BB. Thanks for any info.
   / BB How much weight to add #2
I am currently using four, 42lb JD weights because that is what would conveniently fit on the existing structure. I am planning on fabbing up a weight bracket that would allow six or seven of such weights, mainly for when I want to use the box blade as a counterweight.
   / BB How much weight to add #3
This is what I use.:D
   / BB How much weight to add #4
Maybe the ground I have around me is just easy to work with but I have never needed any weight. I use the scarifiers when needed and smooth things out as needed.
   / BB How much weight to add #5
The guy I bought my used Kubota B7800 and LandPride 54 inch BB from had added weight to the BB. He used a 54 inch long piece of I-beam. Drilled two holes in the top, drilled matching holes in the top rear frame of the BB, hung the I-beam on it and dropped two bolts through the holes. Don't know for sure how much the I-beam weighs. I'm guessing 150 lbs or less since the wife and I can pick it up and move it around with some difficulty. I have tried the BB both with and without the added weight. Works much better with the weight, but I have to be careful lowing the 3pt. With the added weight, it drops real fast if I'm not careful.
   / BB How much weight to add #6
I have four suitcase weights and a 6' piece of railroad iron on my 5' boxblade. The weight is mainly for ballast but it does help sink the teeth in my gravel drive. JC
   / BB How much weight to add #7
Just to clarify, I only use the extra weights for ballast because I use my BB for counterweight for the loader/forks. When using the BB for its intended use, I haven't found extra weight necessary.
Also, it makes a convenient place to store the weights when I don't need them on the front of the tractor...
Thanks for the feed back. I have some elevator weights I got years ago, why not sure, thought I might need them some day. That was yesterday, I have used the BB without weight didn't work as well as I wanted even after adjusting the top link. The elevator weights weigh about 280# put one on the BB it made a BIG difference very happy with the results. My camera is down, when I get it back I can post some pictures.
   / BB How much weight to add #9
I use tractor suitcase weight. Either hang them on 2 existing bars in the middle or hang them on the out side edges. I will typically add 250-300 lbs. Easy on/off. Once I awhile, if I hit too hard of a bump, I can bounce them off.
   / BB How much weight to add #10
Here's what I use for my Kubota B7510HST/LA302 FEL and the KK 4-ft XB box blade
Three 120 lb concrete weights. Works fine as FEL ballast and the extra weight really helps that BB work a lot better.
10 GALLON SANDBLASTER (A54757)
10 GALLON...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2013 TIGERCAT 720E WHEEL FELLER BUNCHER (A52707)
2013 TIGERCAT 720E...
Wooden Rocking Chair (A55853)
Wooden Rocking...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2001 Blue Bird Commercial Portable Office Bus (A55852)
2001 Blue Bird...
