BBQ Smokers
   / BBQ Smokers #241
I think the goal of low temp smoking is to prolong the time fish will absorb smoke flavor. Frankly, while I like smoked fish, I see the smoke as similar to a spice and don't want to overpower the natural flavor. I would also like to taste the fish itself. I hot smoked the bluefish and have no complaints. Lots quicker too. A couple or three hours at about 180-190 worked well. I've only used electric to smoke fish. Too hard (for me) to keep precise low heat with charcoal over a short period.
My theory is that low and slow cooking (near or below the boiling point of water) tends to retain considerably more of the the moisture that would be driven off at higher temps while breaking down the tissue. As for smoking wood, I never use green wood nor do I use chips nor do I soak mine.
   / BBQ Smokers #242
Agree. However, if you look at the link MossRoad posted on smoking salmon, the guy smokes at something like 110F for 10-14 hours and then ups the temp to 160-180F for two hours. Smoking at 110 is like leaving the fish out in my black charcoal smoker in the sunshine with no fuel or heat source at all other than the sun (how do you get smoke??). Even my electric cannot generate smoke with a temp setting of 110 as the box heats up too quickly and the chips never get hot enough to smolder. I know there are some cold smoking devices that generate the smoke in a separate box attached to the smoker but I don't have one of those. I'm also not sure I have the patience to spend 16 hours smoking fish if I am happy with a 2 or 3 hour "hot" smoke at 180-190. I guess if someone can convince me that the "cold smoke" step is worthwhile I can figure out how to generate smoke (typical tin foil pouch with fire applied directly to start the chips smoldering and then leave it in an unheated smoker). But I am really interested if anyone has done cold smoking and whether it was worth the hassle.
All of the temps are below boiling point of water (but of course evaporation would be faster at higher temps even below boiling).
   / BBQ Smokers #243
@I.S....are you brining the bluefish?...we always brined them about the same as mackerel and mullet before smoking...they all have similar oil contents...so they did not need to soak long...brining helps retain moisture so cooking times can be long enough for heavily smoked fish (generally the more oily the fish the more smoke required)...the brine will give the raw flesh a very slick texture...
...I've been experimenting with some 18"-20" rainbows and have been brining them for about an hour because they are very lean...using some apple and pear wood...so far so good but it's easy to let them get a little dry...the guy that runs the local grocery/bbq sells smoked trout spread...$10 for 8oz....(BTW...I have an unlimited source for trout without having to leave the property...I just have to "co catching"...)
I like to baste most saltwater fish with Lee & Perins and lemon juice....For presentation purposes...brushing on a light coating of egg white for the last 20 minutes on the cooker will give it a nice sheen...rub or seasoning can be added to the egg white baste...
   / BBQ Smokers #244
Yes, I brine. I think I did the bluefish for a couple or three hours with a simple salt brine then rinsed. I did not air dry before putting them in the smoker. Came out great.
   / BBQ Smokers #245
Last time I smoked something for 16 hours I was in high school.... :rolleyes:
Anyhow, I don't have that kind of patience either. I don't mind smoking foods at home on a weekend when I'm doing yard work or hanging around the pool as I'm home anyway and its no bother to glance at the temp gauge on the smoker as I bob around the pool or drive by on the tractor. But I don't want to make it a chore. That would take the fun out of it.
   / BBQ Smokers #246
   / BBQ Smokers #247
I've done this hot smoked salmon recipe many times. It's a 30 minute cook. I've smoked several slabs for a friend. I vacuum seal the slab after it cools, it seals the moisture and flavor in. It has always received rave reviews. Smoked Salmon Recipe | Smoked Salmon Brine | BBQ Recipes | How to BBQ Right
Funny how the terminology varies. This recipe calls smoking at 190 "cold smoking" whereas the recipe MossRoad linked uses 110 for cold and then bumps it up to 190 for a couple of hours. I'd almost call this one grilling over indirect heat rather than smoking because it is so short a cook.
Just goes to show that there are many ways to skin a cat and smoke a salmon.
   / BBQ Smokers #248
...Just goes to show that there are many ways to skin a cat...
And as you likely already know... in some parts of the world (and probably the US too)...it's cooked over coals by street vendors...often called "meat on stick"...!
   / BBQ Smokers #249
   / BBQ Smokers #250
Yep. But that pretty clearly crosses the line and would be called direct grilling in my book.
Shaslik or shish kebab is perhaps the original BBQ. Satay isn't far behind.
5ft Bench Seat (A57454)
5ft Bench Seat...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
SUV (A59231)
SUV (A59231)
22in Frost Bucket (A59213)
22in Frost Bucket...
2016 Komatsu PC240 LC-11 Excavator (A59213)
2016 Komatsu PC240...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
