BBS Help!: Broken Bolt Syndrome
   / BBS Help!: Broken Bolt Syndrome
How big is the broken bolt, I'd get a nut the same or close to it's diameter,
fire up the welder, weld the nut to the broken stud, put a socket and breaker bar on and
start working it back and forth and it should come out.
welding nuts on with a stick welder is my preferred way to remove broken bolts.
The last one I welded on the head had rounded of on so I laid a large nut over it, welded it on turned it right out.
This is my first thought and my usual go-to for removing broken head bolts. According to Messick's, it's a M12*1.25 bolt with a special head. It's about $4 or each. So a little under 1/2"
The problem is if I screw it up: the spindle it's thread into is a threaded shaft (bevel gear, K5668-33500); each one of those cost $148, not counting labor or the time to get to it.
I think I'm gonna pass on welding it myself. I'm going to load it up Monday AM and take it to my local welding shop and see if they can TIG a nut on it.
Thanks,
Much ado about nothin'.
As planned, I took it to my local welder (Terry's Fabrication, Ardmore AL). He has a lot of experience removing broken bolts. It took far longer to lift the ZTR than it did to weld a nut and remove the bolt body.
Just to make sure the other bolts weren't on too tight, I had him remove the other two as well; if one or both had broken, he was already there to remove it. They came out fine.
Thanks for the help, I appreciate it!
   / BBS Help!: Broken Bolt Syndrome #14
I mig weld a washer on the broken bolt first, way easy-er than a nut, and more heat goes to the bolt. Than I weld a bolt or piece of scrap metal on the washer. Let it cool and shrink and turn the bolt out.
Like I told Terry, I was this close to doing exactly that. But I didn't trust myself to not fork it up.
$20 well spent IMO.
   / BBS Help!: Broken Bolt Syndrome #16
I like that and will have to try it at some point. I can see it working better for the shorter breaks.
Suzuki Kingquad ATV (A51694)
Suzuki Kingquad...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
