bcs 715
   / bcs 715 #1
agrik
ireland
honda
just bought an old bcs 715 , looking for a FREE service manual or any other useful info to get it started , thanks
   / bcs 715
thanks , i've already seen it , but what i really am searching is some more detailed info ; how much oil in gear box, how to adjust the carburator , etc...
   / bcs 715 #6
Same page, two clicks further -
http://www.bcsamerica.com/eis/manuals/OpMan.Tractors.PRE%2095.pdf
As far as serious details, BCS manuals lack. BCS America never even had a shop manual for the 700 and 800 series from 1995 to early 2000 and I didn't see any shop manuals on the pages I showed you, either. They had parts breakdowns, but no shop manuals. It's mind boggling that BCS America hands dealers a shop manual for the 715, 725, and 735 from the 1980's and expects them to work on an 853 with them. Lucky for you, though, since you have a 715...
Carb adjustments and such would be covered by the manual for your engine. I do not know of any site that has Acme service manuals up.
   / bcs 715
Thank u , every info is better than nothing :)
   / bcs 715 #8
Here's a quick answer to your questions. Use gear oil SAE 80-90 wt rated GL-5 for the tractor and tiller gearboxes. Fill the tractor gearbox to the upper mark on the dipstick with the tractor sitting level. Fill the tiller gearbox to within 2" of the top of the fill hole again with the gearbox sitting level. Tiller gear oil should be changed with each set of replacement tines.
The carburetors are mostly all fixed main jet so the only adjustment is the low speed mixture. Adjust the screw on the side for smooth running at about 1800 rpm. Don't mess too much with the carburetor as the parts are not available.
   / bcs 715
thanks a lot
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
Year: 2012 Make: Chevrolet Model: Equinox Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 151,614 (A51694)
Year: 2012 Make...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2016 Nissan Titan XD SL 4x4 Pickup Truck (A51692)
2016 Nissan Titan...
