BCS 722 differential question
   / BCS 722 differential question #1
louky1150
Kubota
Greetings: I just traded a BCS Diesel 853 Tractor for a BCS 722 for the purpose of downsizing, smaller garden, diminishing muscle mass. The 722 runs fine but I noticed that the tractor won't "pivot" the way the 853 did (one wheel going forward and the other backwards). There is no "differential" engagement lever like is on the 853. Am I correct in thinking that this tractor drives with both wheels all the time and I can't expect it to pivot the way the 853 did? Thanks in advance!
   / BCS 722 differential question #2
Hi louky1150 ;)
I think that you are absolutely correct regarding your BCS 722:
BCS 722 - 8HP - Earth Tools
As you can see, Joel states that the BCS 722 has no differential. This means that both wheels are mounted on the same „solid“ axle, and will move as one unit. This is probably one of the disadvantages of a smaller tractor, compared to your BCS 853 :cry:
Best regards
Jens
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A46684)
2018 Toro Grounds...
2012 Volkswagen Jetta Sedan (A46684)
2012 Volkswagen...
Rims and Tires (A49339)
Rims and Tires...
Antique Kinkade Garden Tractor 36in. Sickle Mower (A46502)
Antique Kinkade...
Skidloader Trailer Mover (A47809)
Skidloader Trailer...
2018 Ford SuperDuty F-250 (A48561)
2018 Ford...
