BCS 725 Kohler Magnum 8 w/ Carb Problem
   / BCS 725 Kohler Magnum 8 w/ Carb Problem #1
ttkeeler
When I try to start it after a few pulls on the rope starter fuel starts dripping out the air cleaner. I did get it to fire once but its obviously flooding the carb now. The float must be stuck, how easy are these carbs to work on? Any other ideas?
   / BCS 725 Kohler Magnum 8 w/ Carb Problem #2
You may have to remove the air filter housing to get access to the carb.
Just unscrew the bolt on the bottom of the carb. The float bowl can be pulled down and off. There should be a float on a pivot that goes up and down to close and open the needle valve to the carb. Pull the pin out of the pivot and the float will come off, and the needle will probably fall out and get lost if you're not careful. Get some cotton swabs and some carb cleaner and clean out the gunk in the needle valve seat. Clean off the needle valve and put it all back together.
If this doesn't work for you, just say so and I'm sure somebody will have a better answer to help out.
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A57880)
2005 INTERNATIONAL...
2004 Altec AT37G 37ft Insulated Rover Bucket Lift (A55852)
2004 Altec AT37G...
MAHINDRA 6500 TRACTOR (A57192)
MAHINDRA 6500...
1000000 (A47477)
1000000 (A47477)
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
Case Titan 3530 (A56435)
Case Titan 3530...
