BCS or DR? Ferrari vs Chevelle?
   / BCS or DR? Ferrari vs Chevelle? #11
Gio: checked the BCS brush mower specs today; it is indeed a 1/4" bush hog type blade. Expect it would be as good or better than DR.
Bill: Thanks for the great link showing the flail mower in action. The terrain and brush being cut along the stream bank is almost exactly the application I would be using. The flail mower also looked less "front heavy" than the "bush-hog" type brush mowers. The steering brakes seem like a really good idea, wish they had them on the smaller models. Good advice, thanks.
Bill, Thanks for the link and the sound advice. I am going to give Earth tools a buzz and weigh my options.
Nomad, thanks for the spec check.
   / BCS or DR? Ferrari vs Chevelle? #13
Hi Gio:
Did you decide what to get? I went with Ferrari after driving a Chevelle.
I was asking similar questions this year. I used a 26" DR Brush Mower with a 17HP Kawasaki for 10 years on our mountain property. Originally I had the same misgivings like Bill in WI about the marketing-driven DR operation but overall I found it a decently designed and built machine. It served me reasonably well but when I lost it in a fire I decided to not replace it and go with the BCS platform instead. Here are my gripes about the DR:
- I did not like it to be "single purpose". At 17hp the DR really is a walk-behind tractor but with a very small number of options. It seems they understand it because they offer a few more implements now than 10 years ago but some of them seem like an afterthought. The belt drive instead of a PTO is a limitation. It's not really a platform like true walk-behind tractors.
- The belt-drive causes power transfer losses. I think that's why the engine has to be so big.
- The big engine sits high above the axle and raises the center of gravity. This doesn't matter if you mow a fairly level property but it's an immediate problem on slopes.
- The mower wants to roll when you mow across the hill and you end up manhandling it to keep the upper wheel on the ground. You don't just "walk behind".
- If you mow up the hill you must pull up on the handlebars to keep the mower deck on the ground and prevent a wheelie; down the hill it's nose-heavy and you must suspend yourself on the handlebars to prevent the mower deck skids from "plowing" the ground (my neighbors like to watch me doing the calisthenics, I think).
- The limited slip differential is truly "limited". It rarely prevents a wheel from slipping. I've heard that some owners retrofitted a real lockable differential.
- The handlebars seem flimsy and too flexible for such a heavy machine.
- There are no steering brakes. When you mow across the hill and the deck tends to pull downhill you must keep it going straight with the handlebars.
- The machine is built more like a motorcycle than like a small tractor; it did not do poorly in 10 years of seasonal use but it would affect longer term or heavier use durability.
All that said I liked the machine well enough to not seriously think about a replacement until the fire. It's not cheap but it's less than a comparable 2-wheel tractor with a mower deck. It has a decent ground clearance and an approach/departure angle with standard wheels. The belt drive allows a single straight heavy blade---no breakaway joints needed. The mower is not light but I was able to manhandle it on the slopes (my wife never tried and I don't think she would have enjoyed it like the ladies in DR advertising but it was not a problem for me---I don't like going to a gym).
After the fire I had to and could start from scratch and I settled on BCS over Grillo but it was a close call. Bill in WI has listed some of the reasons why it's not a slam dunk decision.
I bought the BCS 852 with 6.5x12x23 wheels and a 32" Zanon Brush Mower. It works well and even with the much wider and heavier deck it is quite civilized. I also bought a 40" Grillo snow blade with it but haven't used it yet. Other implements will have to come later but I am lusting after a big front cart (our budget may dictate something like oldmech's solution).
I hope that later I'll be able to report more on using the tractor on our mountain.
   / BCS or DR? Ferrari vs Chevelle? #14
Just my :2cents:
I have a DR Mower 17hp that I used for mowing blueberries and my fields. I've had it for 7 or 8 years now and have a snow blower for the winter . I will say, it does take a bit to handle it , turning it while pushing down on the handles when you want to turn around after a couple of hours gets old .
I've been able to cut what ever I wanted without stalling the motor, and they have a bush blade to be able to cut thicker stuff. It's like anything, you just have to get use to how to work it . I like the idea of the belts , because when you do hit a rock or stump ... whatever it will just slip on the belt for a second and no damage done but to the blade. There one beast of a mower, and I wouldn't part with it . Besides buying a belt for my snow blower and a couple of shear pins and a battery plus changing the oil and filters, I've never had anything go wrong with it , and has always started even on the coldest days.
Never had any power loss even going though thick wet grass . The only time there were any loss of power was when I hit something solid, like a rock.
I would like to see it have a different setting for mowing heights , but it cuts good without much of a mess left behind , if you blow what you just mowed into what your going to cut next.
As far as a snow blower goes , it'll blow dry snow 30ft and wet stuff like 10 or 12ft. I'd like to put chains on it ,just to see what it would do!
320 Gal Fuel Tank (A53316)
320 Gal Fuel Tank...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2006 International 4400 DT466 (A53314)
2006 International...
2005 Chevrolet C4500 Landscape Dump Truck (A55788)
2005 Chevrolet...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55302)
2017 KINZE...
