Bearing replacement on tiller
   / Bearing replacement on tiller #12
Can you get that C clip off with a pair of pliars or needle nose pliars?
   / Bearing replacement on tiller #13
I second the puller.
   / Bearing replacement on tiller #14
The key should be softer metal than the sprocket or shaft. A three prong puller should pull the sprocket off the shaft.
Another option if you have room between the sprocket and frame to get a pipe wrench on the flange of the sprocket and block the shaft so you can get the key back in the key way.
   / Bearing replacement on tiller #15
Yea it definitely twisted. Any recommendations on turning it back?
You could take a plumbers pipe wrench on the shaft of the tiller,
give it a few good shots, backwards while someone watches the key way.
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
New/Unused SD Lanch SDLL50 Mini Skid Steer (A54865)
New/Unused SD...
2012 Ford F-550 Crew Cab Truck (A55852)
2012 Ford F-550...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
