Bedliner spray on step tubes / nerf bars?
   / Bedliner spray on step tubes / nerf bars? #1
lostcause
Maine
I just traded for a new truck, and i was able to recycle all the add-ons (floor liners, bed mat, bed cover, step tubes) since the truck is essentially the same, just a few years newer... The step tubes I bought were stainless, and after 5 years they have sandblasted the original matte textured powder coat off the leading faces and a lot of the underside areas - aside from that, they look pretty good since they didn't rust. I'm thinking that I'd like to try a bedliner spray on them and I'm wondering whether anyone has tried here? There's lots of pictures and text blurbs online, but most of the pictures are of nice clean vehicles sitting in suburbia driveways. I don't live in suburbia, and while most of the roads i drive regularly are paved, they are also covered in sand for several months of the year, so there's a lot of abrasive spray up from the tires. I'm looking for any feedback on abrasion resistance.
I'm thinking of line-x. they seem to spray to a decent thickness, and the coating is hard, so I'm thinking it may be fairly tough in this respect? i've had linex in beds before, and it seems reasonably abrasion resistant. I've had it chip out a couple dime-sized chunks when hit with sharp ends of heavy steel bars, but those were not normal use. I've used Raptor clear spray on with a color match paint added in to do rocker panels before, but it's softer, and after a couple years it had started to sandblast through. I'm thinking thicker and harder would be best? Any experiences out there?
   / Bedliner spray on step tubes / nerf bars? #2
I think lineX would hold up fine, I've seen a number of steps coated with it and no problems after years of use off road.
It's soft enough that the sand being kicked up won't wear it down, just absorbed the impact.
   / Bedliner spray on step tubes / nerf bars? #3
I used Amazon.com
after using Rustoleum Rust Reformer.
It hardened up some, staying slightly flexible. It doesn't hold up to the dirt/gravel road I live on.
   / Bedliner spray on step tubes / nerf bars? #4
I used Amazon.com
I haven't found a DIY bed liner that holds up well enough to be worth it. Even some spray on commercial versions aren't great.
LineX is a whole different level.
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
