Bedliner, what type and where to get it
   / Bedliner, what type and where to get it #21
If so, it has a bit more CFMs than mine but not the 8 CFM that the Raptor product spec's, so mine might work too. Also, Todd's compressor has almost the same spec's as mine and worked for him, so it's probably worth a shot.
I had no problems whatsoever. Heck, I never even looked at Raptor's CFM spec. I was going to use the compressor I had no matter what. It's 120V. Not like I had to lay down a glass smooth finish. :confused3: The instruction sheet says shoot it at 40-70 psi. I think I set the regulator to 50-55 and went to town. You can probably adjust as you go depending on temperature and viscosity of your mix.
   / Bedliner, what type and where to get it #22
Is it this one - 120 volt? 30-Gal. Cast Iron Portable Electric Air Compressor-VT6315 at The Home Depot
No, that is not it. Mine is 15 years old. Its rated at 6.5@40 & 5.1@90 & is a 150 psi model. Its not 30 gal like I thought but 27. Its a cheap $299 unit that came with a hose, air ratchet, cut off tool, impact, spray gun, ect. Its done lots of work for the price.
Chris
   / Bedliner, what type and where to get it #24
If you have a 60 gallon tank on your compressor, it will put out as much volume as your hoses will handle until the pressure drops to your spraying pressure. Might mean 5 minutes of spraying then 5 minutes for pressure to build back up.
Spray, drink a beer...
spray drnk a ber...
spry, drunk a-bear...
oops.
   / Bedliner, what type and where to get it #25
2017 FORD F-550 SUPER DUTY CAB AND CHASSIS (A58214)
2017 FORD F-550...
Chevy 2500HD (A56436)
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2020 Ford Ranger XL (A57148)
2020 Ford Ranger...
UNUSED AGT SSECAG-Y HYD AUGER (A58376)
UNUSED AGT...
Fork and Frame Skid Steer Attachment (A56857)
Fork and Frame...
