beet juice
   / beet juice #1
grasswhacker103
2017 ventrac 4500Z
does anyone have beet juice in their tires and would you recommend it or some other tire ballast ?
   / beet juice #2
I recommend it, it's environmentally safe and non corrosive. Search for RimGuard if you cannot find beet juice.
   / beet juice #3
If I had 4-ply rated AG or turf tires I'd want wheel weights vs worry about the mess of a tire puncture. With 6-ply R4s I don't worry about that, even when grappling thorny stuff like autumn olive or locust.
I'm quite happy with Rim Guard and recommend it. Just one trick: rotate the air valve to the top and puff a wee bit of air into it when checking tire pressure. (still important) This should minimize gumming up a pressure gauge.
   / beet juice #4
I had Rim Guard installed in my Kubota when I bought it in 2009. Not had a bit of any problems with it. I, first year, used the 12 'O clock high method to check tire pressure. Now - much easier method. Roll the tractor out on the rock hard driveway. Check that the rear tires leave a chevron pattern all the way across the tread. For my tires that equals around 16 psi. Front tires are set at 30 psi. 30 is max recommended on tire sidewall. I run R-1 tires.
   / beet juice #5
My 2019 tractor came with filled tires. Does anyone know what fluid the dealers typically use to fill the rears. I both hope and can't believe it's pure water.
   / beet juice #6
Let out a squirt or 2 and do a taste/smell test.
Salty= bad news, sweet= great, that's 'beet juice', tasteless= pure water.
Or U could freeze the juice to determine if cold protected B4 doing the other tests.
(Water could be polluted but doubt beet juice/salt would be.)
   / beet juice #7
I don't think there is a "typical" fluid. Roll your valve stem to 12 'O clock and press the valve pin - just momentarily. This will give you a tiny bit of whatever is in the tire. Pure water( I doubt ) - NaCl laced water( I hope not ) - RV antifreeze or windshield washer fluid - that's OK - - Rim Guard - that's OK. Taste whatever sprays out on your finger - it won't make you sick or kill you.
If we knew where the OP lived we might eliminate pure water. NaCl - salty. RV antifreeze or WW fluid - might have slight alcohol taste. Rim Guard - dark red, like blood - thick like maple syrup - very sweet.
   / beet juice #8
Then there's that cheap vodka that wasn't high enough proof to be used as a disinfectant. :D
If you're not familiar, the problem with 'chloride' is that it's so corrosive. CaCl granules will 'sweat' at >18% humidity. (hygroscopic) In any common environmental condition it's giving what it touches, is spilled onto, etc, a salt water bath. In Michigan it's sprayed onto dirt roads to keep dust down. Cars rust and winter road salt get blamed, but it dries at < 82% humidity.
There's oxygen in water, so rims can rust from the inside if any gets past a tube and between a rim. Chloride in tubeless tires is just scary to think about.
   / beet juice
thank you.
   / beet juice #11
My 8 Ventrac wheels have 7 gallons of winter grade windshield washer fluid plus a pint of Ballistol to prevent corrosion. Beet juice is heavier and better except for the potential mess and it smells a bit.
prs
   / beet juice #12
Tire fill is the best use invented for beets. Those foul things should have been left in Europe. :D
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
1991 International 4900 Box Truck (A55315)
1991 International...
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
2004 JOHN DEERE 650H LGP CRAWLER DOZER (A60429)
2004 JOHN DEERE...
