Befco 4" rotary cutter (brush hog) run CCW?
   / Befco 4" rotary cutter (brush hog) run CCW? #1
Freakingstang
BOhio
s370d
I ran across a heck of a deal on a free 4' befco brush hog. The rear part of the deck where the rear mount for the wheel attaches was cracked and seperated. Easy fix...
Now, since I haven't located a PTO reverser for less than I paid for my tractor.. can I run this cutter in a CCW direction? I would have to put some kind of edge on the blades. What about the attaching bolts? will a double nut work, or should a get a keyed bolt/cotter pin, or lust look for left hand thread bolts and nuts? The gear box shouldn't matter what direction it turns as long as it has oil right?
   / Befco 4" rotary cutter (brush hog) run CCW? #2
Hey, did you ever get this figured out? If the PTO yoke that slips on the tractor is the standard 6 spline it should be CW not CCW. I just bought a used 4 footer today for $325.
No it's been on hold, still need to fix the rear wheel. My pto is Definately counter clockwise, but I have a splined adapter that makes it the STD 6 spline. Haven't found an affordable reverser yet.
I was going to get ahold of befco and see their thoughts but it's been on the back burner.
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2013 PETERBILT 367 TRI-DRIVE (A55745)
2013 PETERBILT 367...
Case VAC Tractor (NOT RUNNING) (A50775)
Case VAC Tractor...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2021 Honda Pioneer SXS700 4X4 Utility Cart (A55788)
2021 Honda Pioneer...
