Belarus 250AS decompression lever hard to move
   / Belarus 250AS decompression lever hard to move #1
Caracal13
Belarus 250AS
Hello,
I have a Belarus 250AS that I am trying to get running and have a problem with the decompression lever. It is hard to move. At the engine case, I have to pry the rod backwards to open the compression so the engine will 'free-wheel' as it should. I then have to push the lever forward with my foot to close the system for compression. I hope that makes sense. It is functioning when I use this process, but the lever should move freely using the control lever. I have sprayed quite a bit of PB Blaster where the levers enter the engine case, but that has not loosed the levers to where the rod will move freely. Any thoughts on how to get the rod to move freely would be appreciated. Hopefully this does not mean 'cracking' the case.
Thanks,
Caracal13
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2012 EZ-GO Cart (A55853)
2012 EZ-GO Cart...
Metal Bigfoot with Flag Lawn Art (A55853)
Metal Bigfoot with...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55314)
2023 Kubota M4-061...
2021 KUBOTA SSV75 SKID STEER (A52707)
2021 KUBOTA SSV75...
