Belarus 400AN
   / Belarus 400AN #21
You can buy Delco starters on e-bay for much less money than a new Belarus starter.
   / Belarus 400AN #22
Hydraulic leaks on Belarus tractors is a very easy fix! The factory uses copper washer seals on the many banjo fittings in the system. Get ahold of some domestic washers that are made out of softer material and problem solved.
   / Belarus 400AN #23
If the cooling fan belt is tight, and there is no clutter where the air passes through the cylinders, you can NOT over heat an air cooled Belarus. If it is well maintained, it will run very cool.
   / Belarus 400AN #24
Dude, 12 year old thread.
9000 (A47477)
9000 (A47477)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
