Belarus 820 hydraulic problem
   / Belarus 820 hydraulic problem #1
mel8030
I have a pre Husco hydraulic system. Everything worked ok when parked 6 months ago. after starting, the hydraulics has very little pressure. When the 3 point lever is moved, the 3 point arms will creep up but I can push them back down by hand. Acts like there is a huge internal oil leak. When the level is released, the 3 point arms will lock and stay in place.The remotes also have very little pressure. Oil will shoot out if remote line is opened and lever moved..
I have removed cover # 41 in link and inspected the spool. Everything looks ok.
Hydraulic Implement System -> ?80-3/4-222-3? Hydraulic Control Valve
Any other idea? Can a pump go bad just setting there? Maybe some ice formed in the pump during this cold winter and broke something?
I have 2 repair manuals but they don't go into hydraulic trouble shooting or explain the oil flow. Is there a detailed hydraulic manual?
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
(9) 55 GALLON METAL DRUMS (A60432)
(9) 55 GALLON...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
11" TRUCK BED (A60432)
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
