Belt Tensioner
   / Belt Tensioner #1
dieselscout80
South Carolina
New Holland TC45DA
I have a Ford 917 flail mower. Over the years I have had to adjust the belt tension semi regularly.
I have been spoiled by the serpentine belts in automotive applications in that they have automatic tensioners.
I wonder if an automotive belt tensioner could be adapted to my 917 flail mower?
   / Belt Tensioner #2
No reason it couldn’t be adapted, but I have a 917H with the spring tensioner, other than lacking the serpentine belt, the tensioner is just a large, clunky version. Also, I use my flail two to three times a year for about five hours each time, but don’t tension the belt, but every two or three years.
   / Belt Tensioner
I didn’t know a 917h had a spring tensioner can you post a picture of it?
   / Belt Tensioner #4
You are right, no spring. Don't know what I was thinking, but it could be added very simply
Getting old and confused. 😕
   / Belt Tensioner
I wonder if an automotive valve spring would work?
   / Belt Tensioner #7
Maybe a pair of them or a long spring.
   / Belt Tensioner #8
A spring for a screen door just cut to size
willy
   / Belt Tensioner #9
All of the 917s I have owned, had a spring under the adjusting nut. I used whatever I could find, but the stiffer the better. A valve spring would work.
   / Belt Tensioner
The two 917 flails I have owned did NOT have a spring. The manual I have does not show a spring.
If one has been added to yours, can you post a picture of it?
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
PREVIEW DATES AND TIMES (A57453)
PREVIEW DATES AND...
(5) Seats (A57149)
(5) Seats (A57149)
POWER WASHER (A58374)
