Bending square u-bolts with shop press
   / Bending square u-bolts with shop press #1
TimBuck2
Bronze Member
Central Massachusetts
Kubota L4310 HST and Ford 841
I am refurbishing an old Cox boat trailer and have been searching and searching for the correct size square u-bolts to fit various applications. I have decided it's impossible to find something you can live with, never mind finding a size you want.
Has anyone fabricated a "die" set up for their shop press that does a decent job of bending square u-bolts?
Seems like it should be pretty straightforward ...
Thanks,
Tim
   / Bending square u-bolts with shop press #2
I wouldn't do that on a boat trailer. Too much liability. Same reason most welders won't weld anything on a hitch.
Too many variables like stress fractures, crystalline structure, work hardening, just to name a few.
Have you tried contacting a Cox dealer for the correct part?
   / Bending square u-bolts with shop press #3
Some marine supply houses have boat trailer parts...
   / Bending square u-bolts with shop press #5
I haven't done this for axles, but other places I've replaced U-bolts with a heavy strap and two standard bolts. Probably stronger than DIY U-bolts.
Bruce
   / Bending square u-bolts with shop press #6
Most boat trailer u-bolts are galvanized after they are bent...
   / Bending square u-bolts with shop press #7
For most any hardware, the answer is almost ALWAYS McMaster-Carr...
   / Bending square u-bolts with shop press #8
   / Bending square u-bolts with shop press #9
You'd be better off drilling flat steel stock and using bolts and nuts than trying to bend your own. As MB hints, bending All-Tread never ends well.
   / Bending square u-bolts with shop press #10
Could you just use an upper plate and a lower plate with two regular bolts?
2017 FREIGHTLINER M2 106 26FT NON CDL BOX TRUCK (A43004)
2017 FREIGHTLINER...
2002 Ford F-150 Pickup Truck, VIN # 1FTRW07332KD61848 (A44391)
2002 Ford F-150...
2012 INTERNATIONAL 4300 CAB AND CHASSIS (A43004)
2012 INTERNATIONAL...
2004 Sterling Acterra 1,000 Gallon Water Truck (A45336)
2004 Sterling...
2012 Ford Escape XLT SUV (A44572)
2012 Ford Escape...
Wacker RT Walk behind Trench Compactor (A44391)
Wacker RT Walk...
