Bent Clevis Pin I’m rear PTO. NH TZ25DA
   / Bent Clevis Pin I’m rear PTO. NH TZ25DA #1
nasonjo
Mahindra 1816 HST
Hey guys. I just bought my first attachments for my tractor... PTO Tiller and Bush Hog for my New Holland TZ25DA. Upon looking over the connections I noticed that the clevis pin on the turnbuckle was bent on the left side. I am having a bear of a time finding this part on any manual or on Messiks. It seems like it would be a common part. Does anyone know how to find a replacement. Do I need an exact replacement for both sides? Or just need the same length? Pictures attached. IMG_1609.JPGIMG_1611.JPG
   / Bent Clevis Pin I’m rear PTO. NH TZ25DA #2
Along with finding a new part - determine what caused this and make necessary corrections.
I only have a theory that the previous owner backed into something with an attachment because it looks like it buckled and a little nub on the top link was bent. Everything operates fine and there is no visible damage to any other parts or the PTO.
I would just like help finding a replacement part if possible.
And after writing that and reading it the buckling theory doesn’t really make sense because it couldn’t buckle without damaging anything else...
   / Bent Clevis Pin I’m rear PTO. NH TZ25DA #5
Re: Bent Clevis Pin I知 rear PTO. NH TZ25DA
I can't help on replacements but I would at least try to straighten them. Screw a couple nuts on, clamp in a vice, warm up the bent area and straighten them.
I did with a hammer, it is fairly straight just need to repair a couple threads. I think it will work but I just don’t want it to fail while I’m working... but those shouldn’t really take too much stress I wouldn’t think.
   / Bent Clevis Pin I’m rear PTO. NH TZ25DA #7
The majority of the stress should go to the lower arms and pins. But anything can be abused. Personally I am not a big fan of the solid screw type. The solid bar type are fine. For the screw style, I like those that have a few chain links in them. That way they are set up to give if pushed against while pushing in reverse.
As to repairing the threads, a thread file or a triangle file sometimes works. A die the right size should work also. If you hammered on the threads, one of those is going to be the best solution.
   / Bent Clevis Pin I’m rear PTO. NH TZ25DA #8
Google SBA370501130 and SBA370501120. Those are the part numbers for each threaded end, and Messick's shows both in stock.
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A54865)
2012 Ford Transit...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
1993 JOHN DEERE 444E WHEEL LOADER (A52705)
1993 JOHN DEERE...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A55788)
2019 Ford F-350...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
