Bent Hitch Pin
   / Bent Hitch Pin
I got that ucker. It had a solid bar in it. The pin and bar stock look like they slide in the slot and cushioned by the rubber in the ball end of it.
Sent from my iPhone using TractorByNet
   / Bent Hitch Pin #12
WOO HOO! :thumbsup:
   / Bent Hitch Pin #13
You have a much bigger problem my friend. In the first photo it appears you have cracked welds against the hitch frame. Is so badly rusted its hard to see but I think they are there. You also need to craw under and check your hitch frame bolts. I suspect based on the load it takes to bend the hitch pin you have probably started to deform them.
Please get yourself a new hitch and possibly save your life and those of others if it comes apart. A new hitch now will give you peace of mind. While you are at it you could also upgrade to a heavier one.
To keep mine in operating order, I remove the hitch when not in use and spray with WD-40 before and after each use.
   / Bent Hitch Pin
I double looked at it. The frame looks more scary than the hitch or bolts. I'm having second thoughts on a bumper pull anyway. I talked to the guy today and I can get a nice goose neck for a little more. I may just use the hitch for my winch I have three goosenecks now so one more won't hurt.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2011 WESTERN STAR  4900 SB (A55745)
2011 WESTERN STAR...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
