bent hydraulic cylinder???
   / bent hydraulic cylinder??? #11
Diamond I also straightened a cylinder rod on a backhoe, in the most primitive way, by blocking under it and using the hydraulics. I believe 3RRL did something similar and documented it in the archives. A search will pull it up. It is kind of like, " what do you have to loss".
MarkV
Well I went out and lifted the loader, disconnected the piston rod end from the bucket and flipped them over and re-pinned them. I then used a block of 2x4 and worked one side at a time against the loader frame bending the piston rod using the tractors hydros by manipulating the curl on my loader. I did it in small steps checking with a metal strait edge as I went. I was able to work it back from 1/4" bow over 24" length to less than 1/16" of bow. I am happy.
Thanks for all the suggestions.
Chris
   / bent hydraulic cylinder??? #13
Hi Chris,
I see Mark already pointed you in the right direction and you fixed the problem already too.
Great job! If you didn't find the link to what I did, maybe Mark could post his thread link where he straightened his out. I remember reading about it and it works. My original post was when I re-positioned Loretta's cylinder attachments on her Jinma 284. The factory fel cylinder attachments allowed too much dump and actually caused the rods to bend. I did it all at camp. You may have read about it?
Rob-
Hi Chris,
Rob-
Yes, I remember it Rob. You did a fantastic job at re-engineering the loader to not allow that to happen.
Chris
   / bent hydraulic cylinder??? #15
I've bent two cylinder rods.
One was just slightly bent, maybe 3/4 inch out of straight - used the hydraulic press - a couple careful pushes - and put it back to right.
The other, well, was really bent - more than 45 degrees - a real kink! Tried the press, all was going ok, 'til it started making all sorts of cracking noises.
Turns out there is a hard surface/plating on the rod that doesn't like to do a lot of stretching and bending, ended up with literally thousands of surface cracks.
So... I treated my bucket truck to a new cylinder.
I like, and have made mental notes on, some of the ideas posted here - hope I don't have opportunity to try them out too awful soon though.
Thanks,
Bob
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
17302 (A55853)
17302 (A55853)
2014 Infiniti QX60 SUV (A53424)
2014 Infiniti QX60...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A56138)
1999 INTERNATIONAL...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
