bent hydraulic lines...what now?
   / bent hydraulic lines...what now? #11
The stainless tube I work with (.049" wall thickness and seamless) is harder than the standard steel tube I work with. Both the same wall thickness. It is more difficult to bend and flare. I used to stock more stainless as the price difference is almost nothing, but it is definately harder to work with. Now this is just the stuff I had from my supplier, yours may be different. This is just my experience with the tube from my supplier. You may not be wrong. Believe it or not, brake line is of lower quality than the tube I get.
   / bent hydraulic lines...what now? #12
There's stainless then there's stainless. Automotive grade is usually 400 series. Stainless tube is more commonly 300 series, IIRC. Stainless is harder to bend and MUCH harder to flare. OEM's use some fancy hydraulic tools that don't care what the material, they have power. Use shade tree guys are stuck with hand benders and hand flare tools.
Cheapest way to get the hard line is to buy a bender and some tube and do it your self. Then have a hose shop put on the brazed ends. Use standard steel tube (not brake line - too low of burst pressure). Then paint them up good.
jb
   / bent hydraulic lines...what now? #13
I have purchased and installed JD factory loader hardlines before.
My old JD955s had ridiculously vulnerable lines on the cross tube.
The interesting thing about the new lines was that each came as 2
sections with a compression fitting in the middle. That replaced one-piece
units for ease of installation, I am sure.
Yeah, absurdly expensive, and made of mild steel with what looks like a
nitride coating. I second jb and Wayne....have the new ones made or
make them yourself. I have yet to see any stainless lines on tractors.
BTW, I have noticed hardlines on my Kubota that have nearly worn thru at
support connections. They wiggled a bit, apparently.
   / bent hydraulic lines...what now? #14
The primary reason your replacement tubes came as a two piece deal is that FedEX/DHL/UPS would not be able to deliver them intact in one piece without huge, substantial packaging.
   / bent hydraulic lines...what now? #15
I have bent a few lines.
What I do is take a length if angle (say 1" x 1" x 1/4), lay the line inside and using a sturdy 'C-clamp' and say a similar length of flat, I straighten the bent line by simply tightening the clamp.
Then I paint over the straightened areas with silver Tremclad paint to protect against corrosion.
Works for me.
Now I tend to work my loader hard and have never burst a hard line yet!
A hose or two, but never a hard line.
As someone mentioned, vibration can weaken the line due to friction and vibration, so what I have done is wrapped my lines with a rubber hose length (split to be able to slide over the line) and place under the rigid factory clamps.
This protects the hard lines from vibration wear.
Also every couple of years I Paint any rusty hard line and fittings with Aluminum Tremclad.
Looks better and prevents rusting and pitting!
   / bent hydraulic lines...what now? #16
It could be that you are working with thicker wall material. The brakelines I have replaced very well could have been inferior material. I do not work with this stuff that often and I was just curious why it is harder.
   / bent hydraulic lines...what now? #17
Good point, tho mine were picked up at the dealer. With all the bends,
the factory pre-bent lines would be very hard to install if they did
not have a fitting in the middle. Hard to explain. It is very apparent
in the replacement process.
   / bent hydraulic lines...what now? #18
How do you suppose they got there? A third party carrier was involved, probably several times before you saw them.
   / bent hydraulic lines...what now? #19
If they are crushed in, get some ball bearings that are just smaller than the line ID and put 5-6 of them in there, and then get a wood dowel rod and use it as a cue stick, and tap the lines out... ( this only works for lines that ae mor eor less straight.. ones with 90's you have to use a ball bearing size that won't get stuck at a bend if it is crushed there.. )
soundguy
ladracer said:
i bent two of the four metal hydraulic lines on the front of my loader. those pesky limbs. lines do not leak at the moment but one is fairly mangeled.
anyhow have been told that OEM lines are costly and could be substituted with hoses for much less money.
what say you guys?
   / bent hydraulic lines...what now? #20
Somehow the original hard lines made it to the factory, or were possibly
made there. There are a lot of hard-to-ship items out there. I lost
count of how may custom exhaust systems got shipped to me as examples.
The hard lines are different in that the manufacturer sells a different part
than they install on the tractor, from Day One.
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
2006 Ford Taurus SE Sedan (A55853)
2006 Ford Taurus...
JOHN DEERE 8335RT TRACK TRACTOR (A54756)
JOHN DEERE 8335RT...
2017 CHEVROLET SILVERADO 2500HD (A55745)
2017 CHEVROLET...
