Bent the 4-in1 bucket
   / Bent the 4-in1 bucket #11
Ah, the first time bending a 4n1 bucket! I bought one of these with my ASV, it was my first attachment. One day pulling fence posts, I completely broke out one of the top corners where the clamshell meets the hinge. Welded poorly, it was, so I beefed it up. A half year or so later was trying to dig a old electric pole out, broke the other side, same cause, same solution. Went back to pulling on that pole, and bent the bottom, same as you. My bucket has a double walled bottom piece, had to cut the top wall off with a plasma cutter, then I cut a hole through the top square tube hinge axle, stuck a piece of 3/4" all thread through the hole, welded it securely to the bent piece, cut all corner and bracing welds with the P.C., then tightened a nut on the all thread, and slowly bent the bottom piece back up sans heat! Once it was as close to straight as I could get it, I welded all the cut corner welds and brace welds, and released the nut, it stayed put, so I welded the top plate back on, cut off the all thread. Plasma cutter $2000, Mig welder $2500, Being able to fix my own screwups-PRICELESS!:D
   / Bent the 4-in1 bucket #12
Gotcha:
You are right about heat affecting the temper of the metal, but in this case the grapple is almost certainly made of "mild steel" (1018, 1020, A36, etc) with a carbon content too low to be tempered in the first place, even with very rapid cooling.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2016 John Deer 5075E (A60462)
2016 John Deer...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2018 Ford F-350 (A55973)
2018 Ford F-350...
THREE POINT MAINTAINER BLADE (A58214)
THREE POINT...
