Ber-vac snowblower part wanted, need help!
   / Ber-vac snowblower part wanted, need help! #1
bassontap
Hi, I have a Ber-vac snowblower attachment for my Wheelhorse tractor, Ber-vac model W0246D and I'm having problems finding a simple part for it. It's a cap that has falling off and got lost, now it leaks fluid from the front differetial and my best attempts at fixing it have failed. I contacted the dealer that sold it to me, we have found the part number in a parts book but can't find the part. Any help would be appreciated. Thanks
   / Ber-vac snowblower part wanted, need help! #3
I'm not familiar with that particular snowblower,
but is there any chance there is a seal under that cap
somewhere that is the real culprit with your leak? It doesn't sound right that a simple cap would also be the seal on the gearbox.. but like I said, I'm not familiar with that particular snowblower..
let us know how you make out
/forums/images/graemlins/cool.gif
   / Ber-vac snowblower part wanted, need help! #4
I also own a bervac blower.
If your gearbox is like mine, the filler plug is merely a 3/8" or 1/2" npt pipe plug available from a plumbing supply house.
The other 'plug' ( a 2" or so disc) would be what is known as a 'frost plug' and available from an auto supply house.
These are domed and you simply insert in the macheened hole and bop them with a hammer to expand them into place.
Either part would cost less than $2.00.
Piloon, thanks for the reply, yes it is the "frost plug" as you put it. There is a brass bushing behind it that wants to walk out without his cap. It also leaks oil or gear lube with what I have as a cap on it now. I will try to get a frost plug from an auto parts store and let you know how it works. Thanks
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
Electric Mobility Scooter (A51694)
Electric Mobility...
ROLL OFF BOX (A53843)
